Author Topic: converting >90 to 90spec wiring?  (Read 926 times)
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« on: 27 February 2009, 00:56 »
The title gives it away. Found a good mk2 shell, but its an 89 so obviously running the older loom and fusebox. Whst i want to know is how easy is it to convert to run ce2, using digifant1?
can the existing car loom plug into a 90 spec fusebox using the 90spec digi engine loom, or would it involve ripping the whole lot out, something i have no patience at all for?
failing that, does anyone do a plug & play conversion kit (if they dont, they should, would make a small fortune!)??
Thanks  :smiley:
oh, and no suggestions of megasquirt / standalone, i have neither the money nor the knowledge to do that sort of thing at the moment  :grin:
Offline danny_p
Re: converting >90 to 90spec wiring?
« Reply #1 on: 27 February 2009, 01:21 »
pre > post 90   engine looms on exchange have been threatend before
all the VW's have gone bar 1.
« Reply #2 on: 27 February 2009, 10:09 »
the whole car loom needs swapping, or you need to splice the engine loom into your old engine plug.  loom swap will take you a day at most ;)
