Author Topic: 16valve ignition advance  (Read 6491 times)
Offline dude
« on: 25 February 2009, 08:00 »
16 valve engine code kr.
at 1000 revs set my ignition timing at 7 degrees and goes very well chuffed no pinking !
but when i rev her up to 4600 shes advancing to 48 degrees surely this is to much,or am i doing something wrong
i have followed the haynes manual.
any ideas why this is thanks a lot.
Re: 16valve ignition advance
« Reply #1 on: 25 February 2009, 08:33 »
did you read it with the vacuum hose connected:
2 Run the engine at idling speed and note the basic ignition timing. Pull the vacuum hose from the control unit, then increase the engine speed to 4600 rpm and read off the ignition advance. Deduct the basic advance and the resultant value should be 18°, this being the advance attributable to engine speed.
Offline dude
« Reply #2 on: 25 February 2009, 14:52 »
thanks.
yes did exactly all that.
so that would make my advance 41 degrees. if thats how i think it works.
ive tried another ecu. distributor. what else controls the advance curve i can look for.
thanks rub johnny.
« Reply #3 on: 25 February 2009, 15:14 »
the ign controller is all that controlls advance, maybe the temp sensor is duff?
tbh if the car drives ok and it was the same on 2 ign controllers I wouldnt be concerned, haynes isnt known for being factually correct all the time!  16v info in particular leaves a lot to be desired.  I'll see if I can dig anything up!
« Reply #4 on: 25 February 2009, 15:29 »
I've found some info in the MK1 Bentley on the Scorcco 16v.  However it only talks about CIS-E, but the 'knock sensor control unit' is very similar to our 16v ignition controller, its basically the same but with knock sensing added on.  However that doesnt mean the ign settings are the same, but I would be surprised if they arn't!
RPM-dependant Timing Advance
Start the engine and let it idie for a few minutes to establish a base timing value in the knock sensor control unit. Check and record this base reading. Disconnect the vacuum hose from the knock sensor control unit. Raise engine rpm as indicated, then compare maximum timing advance with the base value:
CIS-E rpm-dependant timing advance:
total timing @ 2500 rpm = measured base timing value {4 to 8 degrees BTDC} plus aproximately 13 degrees
After this check, stop the engine and reconnect the vacuum hose to the knock sensor control unit, if timing does not advance at increased rpm as specified, the knock sensor or the control unit is at fault. See 5, Knock Sensor System.
Vacuum Advance
Check vacuun advance only after determining that the rpm-dependent timing advance is correct. Start the engine and increase engine speed to about 3400 rpm. Record the total timing. Disconnect the vacuum hose from the knock sensor control unit and again raise the engine speed to about 3400 rpm. Timing should advance approximately 6 degrees from the previous value. If not, check the vacuum hose for kinks or leaks. If the hose is OK, the knock sensor control unit may be faulty.
Offline dude
« Reply #5 on: 25 February 2009, 20:08 »
A bit more detail.
the car was originally 8valve kjet done 9 years of road rallying in it and bless her she won a few.
so 3 months ago decided to put a 16valve in spent a grand on a full rebuild. done about 20 mile in it took it to a rolling road and she melted top of piston and smashed head and bottom end.Great!!!!!!!!!!!. On the rolling road she was advancing to much 40 degree plus 2 injectors were not working.
So start again, another engine. I put it in at the weeekend with a different ecu & distributor and four new injectors, very impressed with
it.  But after checking the ignition timing here are the figures
1000 revs 8 degrees
2000 revs 24 degrees
3000 revs 42 degress
4000 revs 48 degrees
Ive been told thats too much advance and I dont want this one to blow!
Now then bearing in mind she started out a 8 valve kjet I had to put the 16 valve ecu and ecu loom in it, is there any wiring that
effects advance and retard that I could have forgot to put in.  I dont have the throttle valve wired up, warm up regulator wired up
but I am very pleased with the performance of the engine, its just this bleeding advance problem.
Cheers for helping.  I got a rally in two weeks!!!!
Offline G.T.
« Reply #6 on: 25 February 2009, 22:35 »
          sounds like she's trying ur patiance a bit dude !
« Reply #7 on: 26 February 2009, 11:45 »
nope thats all there is, the dizzy is a dumb unit with no advance built in, no weights or vacuum. or at least it shouldn't, whats the part number on it?
advance is handled completly by the ign control unit, all the rest of the gubbins on the 16v is for idle stabilisation and cold starting
Offline danny_p
« Reply #8 on: 26 February 2009, 12:27 »
that choudl actualy explain things if the dizzy was teh wrong one and started advanceing.
48 deg is a lot of spark and  a lot more than i'd expect to see for max advance,  something is really pileing in the advance between 2000 and 3000 rpm carb dizzys do do that
all the VW's have gone bar 1.
Offline dude
« Reply #9 on: 27 February 2009, 08:34 »
i have tried 3 distributors on it and and 2 senders that the blue and white wire goes on!
got my brothers car here exactly same set up that at full advance is 32 degrees which i would think is correct.
swapped ecu and dizzy off his onto mine but still does the same.
im missing something will be on the job all weekend any more ideas greatly appreciated. thanks R J.
