Author Topic: Braided Brake Lines  (Read 2435 times)
Offline Dan34
  • VTEC Powerzzzz
Braided Brake Lines
« on: 24 February 2009, 21:24 »
Well my brake lines are on there way out and am tempted to get some braided ones. Im just not sure if my brakes will need the 4 or 6 hose kit. Ive got a gti 8v digi with 239mm brakes.
Dan
Offline Organisys
  • Old and Slow...
Re: Braided Brake Lines
« Reply #1 on: 24 February 2009, 21:39 »
If you are going to bother doing it, get the 6 line as this includes the flexible pieces over the rear beam.
Offline Dan34
  • VTEC Powerzzzz
« Reply #2 on: 24 February 2009, 21:41 »
Cheers for you help  :smiley:
and its not that i want to do it, but it needs doing and thought that i may aswell uprate them to stainless numbers so no more rusting
Dan
Offline Ben Lessani
« Reply #3 on: 24 February 2009, 22:29 »
Aren't the braided lines just to replace the rubber unions - not the whole length? If the main lines are shot - I wouldn't have thought there wasn't a stainless equiv - just plain 'ole copper.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #4 on: 24 February 2009, 22:37 »
copper, or better yet kunifer/cupro-nickel.. vw factory lines are steel.. thus why they rustings
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Dan34
  • VTEC Powerzzzz
« Reply #5 on: 24 February 2009, 22:49 »
im not too sure but its ones near the calipers ive been told that they are on there way out and aint alot of life left in them
Dan
Offline Diamond Hell
  • Opinions я Us
« Reply #6 on: 25 February 2009, 08:01 »
If you're going as far as you say you are then while you're at it you might as well move up to 256 or 280mm front brakes and the 16V master cylinder.
You'll get much stronger brakes with less fade resistance.
There's a brake 101 that I put together a while ago here which might be useful.
Offline Dan34
  • VTEC Powerzzzz
« Reply #7 on: 25 February 2009, 08:57 »
Cheers DH might look into changing the hole caliper etc looks like it could be a cheaper option.
Thanks
Dan
Offline Ben Lessani
« Reply #8 on: 25 February 2009, 09:08 »
If you uprate your calipers - the braided unions are still recommended, it stops the spongyness associated with the rubber unions expanding slightly when the system pressurises.
Offline k4ith
« Reply #9 on: 25 February 2009, 21:51 »
good bit of info there Diamond, to clarify
I have bought the 256mm brakes will they bolt right onto my existing 8v set up without req new hubs ? ball joints?
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
