Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240858 times)
Offline DubFan
heres the link guys ,(for runing standalone megqsquirt ms1/2)
 just contact phil on his homepage highly recomended guy,  very helpfull, with help/suport, and he will suject best ecu for ur engines setup ,
(you,ll see a caddy pic of mine on there too, 27psi on a stand alone ms2 ecu ,,,
http://www.extraefi.co.uk/
I spent about 2 hrs reading his Cobra build thread d@mmit.
Quality work though.
You too. Keep it up.
Offline adaptorman
i have to say what a top guy he his ,,,  :wink:, id recomend him to anyone ,,,
at last upgraded ms2 /instailed and got it runing today , also sorted the wideband , which wasnt working correctly on the laptop
http://tinypic.com/r/2h6qzxw/6
Offline adaptorman
still having ecu issusies but managed to do a couple of videos
 first a quick 4wd video
http://tinypic.com/r/fysyp/6
and a couple of road ones , dam mic
bloody cammra man lol al that recoreding and there was onlya quick flash of me
http://tinypic.com/r/k03amv/6
small one
http://tinypic.com/r/2yuy5om/6
little better ,least it got a bit of footage
http://tinypic.com/r/n6x7bc/6
http://tinypic.com/r/zx8jzc/6
quick inside video with 2wd , ull see what happerns , lol
http://tinypic.com/r/2qd73mx/6
Offline Baylez8v
10 days and no updates, u killing me lol
Offline adaptorman
lol theres a good reason for it too , these 24v engine are sh!te , ive blown 3 engines and all ended up in crank bearing failure , after doing some research from companys that build these , this is a common problem on the 24v for either of spun bearings ,or crank failure , and due to the cost of these things ,im going to get a old 12v vr6 and turbo that , main reasons are ,cheeper to buy, and easyer to get hold off, down side im going to make another manifold for the turbo ,,,
Offline Khare
  • The bear that khares
ouch  :sad: Not good then.
At least you've got more sources of a VR6 engine  :smiley:
Offline adaptorman
yep,
going to try a good old 12v  and turbo this , .
so whats next , ive decided to go back to oringal idea and use a mk3 12v vr6 and turbo that , they cheeper to replace, and i should be able to get 20psi from it ,, i know they dont look as good , and maybe a little down on power , but once ive re adapterd it to a turbo , verything should run smooth (fingers crossed)
first the bargin 65.00 ford galaxy engine lol (cd-v6) bought from a auto with a headgasket failure ,, (cheep and cheerfull ) bought it thursday
first the engine
then stripped it/bores look good, crank looks good/ill replaced the timing chains/tensionors/giudes while its out tbh as these are own to be rattley buggars
next went out and got some piping to make a new exhaust manifold  as i carnt use thoses vr6 turbos as theres no room for my turbo
and just had time to chop a collector
then removed the old vr manifolds and noticed some are ovel ,so modifyed the pipes
to fit
 ill make a start on the flanges and start assembly when the engines all built in the caddy and use my 02m gearbox so i can keep it 4wd ,,
Offline Baylez8v
oh bugger, would an r32 block not be an option?? or is that gonna be hard to source parts and overly expensive with the possibility that ull just have the same problems as the 2.8?
i do admire your perserverence (thats probably the worst spelling ive ever done) if id of ever got the tools time and money together, id of still lost hope after blowing the first engine lol
Offline adaptorman
lol ive had a r32 engine same thing crank /bearing failure , its defo a problem with all 24v engines , so chuff em , ill try a 12v , as ive seen more relieable engines and not heard many crank failure problems from them ,,
Offline Khare
any updates dude???
