Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240859 times)
Offline adaptorman
if its next sunday its possible as im having th ecu upgraded to ms2 ,, fingers crossed should be setup and tunied by then ..as i wanted to get a video up , which i try to sort somert out
Offline Khare
  • The bear that khares
Nice one dude! Hope to see you there!
Offline adaptorman
no problem pal ill try my best ...
Offline adaptorman
heres the link guys ,(for runing standalone megqsquirt ms1/2)
just contact phil on his homepage highly recomended guy,  very helpfull, with help/suport, and he will suject best ecu for ur engines setup ,
(you,ll see a caddy pic of mine on there too, 27psi on a stand alone ms2 ecu ,,,
http://www.extraefi.co.uk/
http://www.extraefi.co.uk/gallery.htm
thought this would be of use as theres loads of standalone systems out there which are pricey to buy, the kits are brand new, and  assembled to a high standed, as complete with labled wireing loom, instalation cd, etc ,,,as i know this kit was setup and tunied and runs/boosts a treat , once the niggy tunieing parts were sorted out ,,,
Offline Khare
Nice one mate. Getting to Rtech shouldn't be a problem for you and the 4wd caddy  :wink: Mind you it will be hard putting all the power down  :grin:
Offline leigh_harty
  • Audi AGU
I remember reading all the millions of pages of this on club gti and you got so much stick for making your own (unsafe) parts.. glad you ignored them and built one hell of a machine!
Dont lose your dinosaur!
Offline adaptorman
well my new modifyed ecu arrived at last,
this its a later version of the ms1 ecu , has better processor speed and more ram ,
16x16 tunieing tables , along with loads of differnert settings on it
upgrades 44psi map sensor, laurch control, vvt output to run my varible valve timing
and a qick pic too
hopefully runing again soon
Offline *tell*
good luck mate looks like a good build  :wink:
Offline adaptorman
cheers pal , once i sorted the naughty bits out , hopeing the box of tricks (ecu ) will put this right ,,
Offline adaptorman
having a few ecu problems at mo , setting it up , so its back to basiclys and check the crank trigger first
ecu looks nice inside too with its upgrades ,,
and attempt 2 tomorrow to get the buggar started fingers crossed
