Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240583 times)
nige_s
Coming along nicely now fella. Well done
Offline adaptorman
nice nige , i keep trying , no point in doing a bit then leaving it for months , just keep at it ,, things soon change lol
Offline adaptorman
couple more bits sorted ,
thought id best make the fuel flap work and make a spring clip as i lost the bugger, now works a treat
thought id rip door off as i had a solid one with good pins too
nice solid caddy door lol
may feel odd filling up at the other side of car
 rear axle for the 4wd all wired up and working too
nige_s
top stuff.
Might be the photo but is one of the rear wheels sitting further out than the other?
Offline adaptorman
top stuff.
well spotted because im awaiting a spacer ,, to bring them evern , but because im unsure wee the wheel will sat when powers applied ive left a 5 deg camber on one wheel (inwoulds and 5 deg out on the other lol if u get my drift ,,
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
this thread is insane lol
you have some talent there wish i could pick up a welder
and just fix and make things lol
keep up the good work fella :shocked:
Offline adaptorman
just  get a scrap vechical pratice on  and if all goes wrong least u can weight in and call it a day lol, cheerrob , have a turbo on ur vr6,,, reason i have a turbo wastegate, dumpvalve for one ,, and not a over hard job to sort
Offline Khare
  • The bear that khares
Any updates dude?
Offline Steve_PD
read on another forum that the ecu blown up and it needed a new one and a loom  :undecided:
Offline adaptorman
yep thats right i was about ready for mot when , ive had a problem of not been able to rev the engine limiter past 4000rpm grrr , after basicly ripping removeing testing things , i found it was a ecu problem , so , a guy who was runing a similar ms unit sent me his msq , (me thinking it would cure the problem ) instead , total knackerd things up causeing the ecu to back feed from the 12v feed thew the ecu, and also wipeing my wideband controller out .grrrrr
 so it needs a new ecu . loom , and wideband/controller , lucky guys on the forium helped me out, and ive orderd another ecu ,loom and controller , so in the mine time , i went and borrowed my mates ecu (same set up ) and his has a similar problem , so after checking everything thew found the only problem was 3 parts for the ecu to make the crank trigger spark better and pull thew the engine range , as i was so pissed,,, if id have known this from the start id have never sent another file to the ecu ,,
i have my mates ecu on at mo and the  engine revs to 8000rpm without a problem ,
 so today i made and fitted a better boost pipe  , as the other was catching
, rear tyres fitted , so if i can sort the internal wideband fault ill be in the test station monday lol
other maybe a couple of weeks
