Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240598 times)
Offline adaptorman
i think the side exit exhaust kinda gives the sleeper look away bro LOL
really lmao ,,, i see plenty of corsas with big bore 4inch stuck out of the rear with 1.0litre engines rattleing away ,lmao
didnt think but i reckon this will work , first made a 12mm t3 flange
then redrilled /tapped/ground off and added a divider
then bolted it to the turbo snail , mounted and welded it on
to lift it just enoegh to get a wider return in there plus will make it better for the exhaust when the v bands arrive and ill also be able to change to run both turbos one for the road use which im fitting at mo and the other is for the track ,
welded up and fitted the turbo , and thought , sh!t how do i get a 19mm socket in there lol ,, thought time foe a little adapting mod ,,,,
thought ill get a allen key and weld it on the nut ,,, simple ,
fits a treat
close but bolted back up and just made another return , at a 45deg angle to 5inch down to 45deg over transforbox , and piped back into top of sump
ill have to fire it up 2moz and see if it works any better fingers crossed , heres a quick video of the old one when just reving to 3000rpm
http://tinypic.com/r/102m4as/3
Offline adaptorman
right this after  got a bit pissed with windows not operning so instailed the lot in 45mins lol
quick check for the window switchers
then thow the moters in
then throw the lot back back , just had to make a cap for the doors cards
fitted switchers and then fitted a afr/volt/turbo timer  , had to do a bit of quick chopping but all wired up and done
Offline adaptorman
first knock a hole for extra air
may leave the top part off , lol extra 4inch of cold air may help
awaiting 2 pipes to fit airfilter
then thought make a quick flange to the old downpipe  job done works a treat
quick fire up and the twit spins and spools now , lol
i think ive sorted the old problem as there was a oil splash plate in this turbo and wasnt in the other , and no oil flying out now ,, left it reving at 5500 to make sure lol
next another little mod
fitted some white plazma dails , white thew day , and green or cool blue and there nice and bright too
also all the fuel system is piped up and fuel in the tank and sensor works a treat ,,,
Offline Martz
Awesome thread this. I do enjoy reading a true home brew!
Well done mate, looking forward to seeing this in the flesh at somepoint.
Offline adaptorman
cheers pal ,
bit of messing here but a few short vids of steemy washers/afr gauge/dash mounts gauges , instrument gauges, electric windows lmao , as rain was holding me off a bit
quick vacum test
http://tinypic.com/r/34qw6eq/3
afr test
http://tinypic.com/r/30us5cj/3
incar browze lol
http://tinypic.com/r/33vheyo/3
window quick test
http://tinypic.com/r/rvfxw1/3
Offline adaptorman
not mutch to  only a dam pipe arrived today ,
so thought might as well do the rear 4wd sorted , did the service then made a quick shifter, as i could find ought else to make one with
Offline adaptorman
yesss 4wd is here and works spot on also did some testing as the prime pump only needs primeing for a short time and lasts 20secs on 50/50 once primed ,
and a quick video showing it work
http://tinypic.com/r/wj6s2h/3
Offline adaptorman
fitted new homemade oil return
and thought id add some bullet mirrors from a 60s moter
and a little bee sting too lol
Offline adaptorman
not mutch to add ,bin checking all the nuts bolts, wireing gerneral stuff realy everything up and working
another complete coat of underseal as there were a bit bits i missed
made those front smoked indiactor will fit nicely into the mk1 bumper ,,
quick small video of indicators
http://tinypic.com/r/309pmxf/3
Offline adaptorman
a few parts arrived today ,, so best thought get stuck in ,,
archers, airfilter rubber clamps , mint mk1 door, fuel cap ,bumper too
modifyed a airfilter breather another job out the way just waiting for 2 more clamps
then poped the bumper on
tryed the archers for size,,
not gooding to fit these until im happy with the rest of the car and it gets around to a spot of paint
ill get the door poped on tomoz i reckon ,,
