Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240575 times)
Offline adaptorman
Love this, have been reading bit by bit, really coming together now!
Have you planned its first outing?
soon as its moted lmao , and that shouldnt be too long
Offline adaptorman
not mutch 2day dam wheather ,
fitted brake compansators dosent seem to make mutch differnce with the pedal height
and had the mot man up 2day to come veiw the car and have a check around
pointers i need to do
remove side pipe for mot
fit indactors (front)
too rear tyres
1 seat belt to change has a frade part
one suspension top mount ,has movement ,
other then this everythings go go go
apart from this for the time being , need to sort rear haldex controller  and fit the propshaft.. spray and fill will come later , but had to give it 10min rub over
fitted radio an speakers too lol
Offline bratty
what happened to your split btw after that twit piled into it?
sat in garage in need of tlc , so removed engine and think ill pop it on ebay  :undecided:
gutted man loved the look of that :(
on a lighter note sounds like it needs less for the mot than 98% of the gti forums dailys :D
« Last Edit: 21 July 2009, 19:30 by bratty »
Quote from: Conker on April 28, 2009, 00:32
OMFG. Please tell me you were banging your willy on the keyboard and these were the random words that appeared.
Offline johnson6672
WOW!! I have just sat and read the whole of this thread, awsome, would love to see this when its done, that exhaust manifold is a work of art, you should defo go in to buisness, you would  make a fortune.
Keep up the good work!!!!!!
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline adaptorman
nice one john only homemade stuff pal ,,,if i had a tig welder and the right machincery to cut the pipes correct it wouldnt be a problem
just remade the propshaft ,and im 100percent happy with it , with thicker tube , nice strong stick welded , done in lathe too;)to save any wooble
and found a lump of 4inch alloy tube ideal for makeing a few things for future , ie alloy turbo short runner, air intake, maybe a new side pipe:lol:ideas are endless
« Last Edit: 22 July 2009, 15:47 by adaptorman »
Offline adaptorman
bit morethis afternoon, trail fit of the standard bumper as im undecided wheather i like it or not , ,i might just thow those other homemade ones one for the time
then thought might as well thow the propshaft on , fits like a glove
and quick sterro pic
then thought i better chop a lump of pipe and start on the airfilter as theres not mutch room runing a 4inch pipe , im thinking i need cold air so going to chop a hole in the inner wing and one in the bonett ,thow a scoop on the bonett somert i dint want to do , but with all that turbo/engine heat , i may have to do it , im also going to run a 4inch pipe inside the inner wing , which will blow nicely into the airfilter
Offline bratty
prefer it without bumpers tbh :)
Offline adaptorman
i do but , in a way nice to keep things looking std/sleeper ish  :grin:
Offline adaptorman
well hit a few problems on test run , first couldnt see the gauges as there were too low , so , a quick rip out and re instail on the top of the dash sorted that out
then im havin turbo problems , ie late spooling  and too mutch eccess smoke which im sure is from the hx40 . so had to re do and make a combo (hybrid/with hx40 and a t3/14 houseing ,this should alter things  nicely
but then i think thge problem isnt the turbo at fault but the angle of the return oil feed pipe , grrr , which to move this or angle this means makeing another complete manifold , so ,may be a while longer now
Offline bratty
i think the side exit exhaust kinda gives the sleeper look away bro LOL
