Author Topic: Can the brake servo be fitted the wrong way round?  (Read 1753 times)
Offline Mew
« on: 20 February 2009, 16:57 »
I'm a bit confused.
I can't get my brake pedal to go hard while pumping it with the engine off. All that i have done to the braking system is to remove the master cylinder from the servo, and the servo from the car. I haven't touched the lines at all.
However, i have noticed now that its all back in that my brake pedal is about half an inch from the brake switch light (yet lines up with the clutch pedal) and that when i pump the pedal it won't go hard.
Is it possible to fit the brake servo 180 degrees out, and if so what effect would it have? Something isn't right and i'm not sure what!
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Can the brake servo be fitted the wrong way round?
« Reply #1 on: 20 February 2009, 17:18 »
If the pedal won't go hard, then you have air in the system. As for the brake light switch, the plunger is on an adjustable ratchet. Pull the plunger back out towards the brake pedal.
Offline Benrevs
« Reply #2 on: 20 February 2009, 17:27 »
If it was 180 out, I dont think the vacuum feed would reach..  Does the pedal feel fine/work with the engine running?  Im guessing you checked the seals on the mc? Ben
Offline Mew
« Reply #3 on: 20 February 2009, 18:42 »
that's what i was trying to work out, but that is the only difference betwen the "right way" and 180 degrees out, right?
Engine not running at the mo :lipsrsealed:
No, but it will be replaced soon
Well that's what i first thought, but like i say it hasn't been tampered with so i was wondering if the servo fitted incorrectly would effect it. I guess the hoses have just perished while the car has been laid up for a while. Oh well, braided hoses it is!
Cheers guys
Offline sidecarphil
« Reply #4 on: 21 February 2009, 09:08 »
i fitted my girlfriend a new servo and it was bigger (hers is a 1.3) this one was from a GTi and the pin for the servo was in the lower hole making the pedle lower so the light switch didnt work
i extended the little metal bracket with a bolt
Sorted  :grin: :grin: :grin:
there is air in the brake system that is why the pedel wont pump up as darnPB wrote :)
Offline Mr Blue
« Reply #5 on: 21 February 2009, 11:21 »
get the engine running first.
I messed about with this fork to get the brake light switch to line up
« Reply #6 on: 23 February 2009, 08:08 »
the fork is only used to get the brake pedal at the correct height, line it up to the clutch pedal. (make sure clutch pedal stop is fitted)
to adjust the brake light switch you press the pedal, then yank the pedal switch pin out to full extention, release & press the pedal and the switch self-adjusts.
