Author Topic: Rear disc size + all mk4 calipers fit?  (Read 5393 times)
Offline Gloves88
« on: 18 February 2009, 22:51 »
Just two quick questions really:
What size rear disc's came on 90 spec 8v,16v and G60's? Were they all the same size?
Also if I'm wanting to change to mk4 rear calipers will any fit? 1.8t, 1.6 etc...
Re: Rear disc size + all mk4 calipers fit?
« Reply #1 on: 19 February 2009, 10:40 »
226x10.  I used boggo MK2 pads when I put MK4 rear calipers on my mates car, we kept the old carriers.  Dont think the MK4 pads are actually much different?
Offline Maltloaf
« Reply #2 on: 19 February 2009, 21:05 »
The only difference I found with the Mk4 pads is that there is a slight chamfer on the edge of the pad. I think it had something to do with noise reduction. :undecided:
You will probably have to change the brake line as well because of the banjo fitting.
Offline Dolly
« Reply #3 on: 19 February 2009, 22:00 »
all mk4 rear callipers fit, with later 90 spec (longer) handbrake cables.
rear braided conversion hoses are around £25 from goodridge and can be found on ebay
use mk2 carriers as the mk4 ones dont fit, i used mk2 discs and mk4 pads but they looked excatly like the mk2 ones i removed.
my callipers came from a Bora so if you see those, they will fit.
Offline skem55
« Reply #4 on: 19 February 2009, 22:03 »
would mk4 calipers not work with a pre 90 gti 16v?
as i suspect a seized caliper on mine
Offline Dolly
« Reply #5 on: 19 February 2009, 22:43 »
yeh they would but you need to go to GSF or where ever and buy 90 spec handbrake cables.
must say my handbrake was piss poor fitted the mk4 stuff and 3 clicks and its solid, well happy money well spent.
« Reply #6 on: 20 February 2009, 08:37 »
handbrake cables are not pre/post 90, they're pre/post 87.  You can check what calipers you have by looking at them, handbrake cable to top = pre-87, handbrake cable to bottom = post 87.
I've heard you can fit post 87 calipers to pre 87 car by fitting them the wrong way round, but this results in the bleed nipple being at the bottom so when bleeding you need to whip them off the car and hang the right way up.
Oh and you could get a 256x22 rear disc setup on MK4s models, can be fitted but takes a bit of effort as you cant get MK2 style rear discs in that size, so you need to convert to MK4-type rear stub axles, but MK4 bits wont fit so you need late Polo/Ibiza bits plus then find a disc that fits.  Theres a thread on cgti about converting to MK4 style stub axles if you really want to do this, but iirc I dont recal any easy rear disc fitment.
« Last Edit: 20 February 2009, 08:39 by rubjonny »
Offline Gloves88
« Reply #7 on: 20 February 2009, 12:45 »
Cool cheers for the info.
Only going to do this if I can get the parts cheap enough....currently late mk3 rear calipers are looking the cheaper option.
Have a 90 spec car so cable isnt an issue, found the hoses on TSR for £27.
Anyone got some mk4 calipers they want to sell me for cheap? :D
Offline sleeper16
« Reply #8 on: 20 October 2009, 09:47 »
can you use 4wd mk4 calipers? just iv orderd a set of mk4 calipers from a recon type place and said make sure its the ribbed ones of the 2wd and they sent the plain ones of a 4wd will these work. also the hose fitting isnt a banjo so not sure about the conversion hoses i have on the way. :sad:
Offline sleeper16
« Reply #9 on: 20 October 2009, 11:52 »
on closer inspection the fitting is banjo but has some sort of convertor bolted on to convert it to normal brake union fittings. still though any issues with it being off a 4wd?
