Author Topic: Rear disc size + all mk4 calipers fit?  (Read 5389 times)
Offline sleeper16
Re: Rear disc size + all mk4 calipers fit?
« Reply #10 on: 20 October 2009, 12:24 »
does the 4wd use a vented disc? is that why they cant be used? looking at it the caliper is much deeper than a standard one it looks as though it takes a thicker disc.
« Reply #11 on: 20 October 2009, 14:36 »
the discs are larger plus I'm pretty sure the caliper is a different shape
Offline Mr Blue
« Reply #12 on: 20 October 2009, 18:56 »
The 4wd rear calipers are not the same. The r32 setup I came across were vented. Im sure the 4 motion ones are vented too.
While your there its worth painting up everything. Change the metal lines now if they are rusty. Rear shelds and dust shield for the bearing.
mk4 pads fitted
Offline johnson6672
« Reply #13 on: 20 October 2009, 19:31 »
I am pretty sure most vw calipers will fit on a mk 2 the passat ones look trhe same but check where the hose goes into it, i have a set of Audi A3 calipers which at a glance look the same however the hose goes on the opposite side and fouls the axle, must get my mk 4 ones fitted they are sat in the garage at the moment.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
