Author Topic: Using a Gti head with carbs.........filling the injector holes?  (Read 1862 times)
Offline moonsta
 :sad: does anyone know how you fill the holes where the injectors go if i want to use a Gti head on my latest 1600,wasa told that TSR used to do something?? Any idea's anyone?? Cheers gang :smiley:
Drives '96 Polo 6N and '85 Mk Golf Gti...
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Using a Gti head with carbs.........filling the injector holes?
« Reply #1 on: 17 February 2009, 22:53 »
Araldite some penny coins in there, but don't tell the treasury. You will get into trouble for defacing the head of the Queen! :laugh:
Offline Khare
  • The bear that khares
« Reply #2 on: 17 February 2009, 22:59 »
depends what head. If its a K-Jet head then you can use pennies but you cant on a digi head.
Offline danny_p
« Reply #3 on: 17 February 2009, 23:31 »
depends on how old thw digi head is. per 90  penny trick work it seems
all the VW's have gone bar 1.
« Reply #4 on: 18 February 2009, 09:40 »
leave the injectors in is one way, and gearbox drain/fill plugs fit, though again this depends on the injector hole size as above :)
Offline rodz22
« Reply #5 on: 18 February 2009, 10:05 »
weld the holes up a permanent solution !!!!!!!!!!!
Offline danny_p
« Reply #6 on: 18 February 2009, 11:45 »
welding the holes is suboptimal.   tapping and screw in a threaded bung with threadlock if you must.
Offline moonsta
« Reply #7 on: 18 February 2009, 12:39 »
 It's an early k-jet head.......
Offline danny_p
« Reply #8 on: 18 February 2009, 14:24 »
« Reply #9 on: 18 February 2009, 19:58 »
On the early k jet head, gearbox drain plugs will do the job.
« Last Edit: 07 December 2011, 13:54 by Wayne »
