Author Topic: recaros seats?  (Read 1698 times)
Offline vwjack
recaros seats?
« on: 15 February 2009, 18:55 »
i got some recaros from a rover for £26. i knew they wouldnt fit, but i didnt think the runners just bolted on. i tried to find mk2 recaro seat frames . a guy on edition 38 said i could have his for 150 :laugh:. but can you just replace the whole seat base from and standard mk2 seat and the recaro ones?
thanks jack.
Offline Diamond Hell
  • Opinions я Us
Re: recaros seats?
« Reply #1 on: 15 February 2009, 20:25 »
Recaros are proper.
Their genuine bases cost about £150 each, so £150 for a pair ain't bad.  With a Recaro and a standard G2 seat side by side it should be possible to figure how easy it'll be to set up a homemade base.  I don't think it'll be that easy as Golf2 have three mounts, so you're going to need to be reasonably cute with the fab and you'll need a base to butcher for the fabrication.
Offline ...joe
Re: recaros seats?
« Reply #2 on: 16 February 2009, 23:55 »
I have an account with Recaro, I can get you  aprice for some runners if you like?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline vwjack
Re: recaros seats?
« Reply #3 on: 25 February 2009, 01:01 »
yeah that would be nice joe.
thanks!
« Last Edit: 25 February 2009, 01:03 by vwjack »
Offline ozegti
Re: recaros seats?
« Reply #4 on: 25 February 2009, 02:00 »
Ditto also joe!
Offline vwjack
Re: recaros seats?
« Reply #5 on: 25 February 2009, 10:39 »
Recaros are proper.
yeah i took the g2 seat base off and had a look. it could be done with some welds but it would take time and effort to work out the angle the seat will sit.
Offline ...joe
Re: recaros seats?
« Reply #6 on: 26 February 2009, 08:50 »
i had a chat with recaro and they don't believe that their subframes fit OE seats... i disagree! if you get me a photo of the seat base i'll be able to see what fitting they have.
If i can work out if they'll fit, they'll be about £80 each plus postage.
Offline vwjack
Re: recaros seats?
« Reply #7 on: 26 February 2009, 13:12 »
thanks joe for that!
i forgot when i phoned that guy i asked for a part number maybe that will be some help to you joe.
but ill get you a photo of the rover seat frame and the seat mounts.
thanks again joe!
Offline ozegti
Re: recaros seats?
« Reply #8 on: 28 February 2009, 12:57 »
I need the measurements across the base (width of the seat rails hole to hole. My recaros have the same bolt pattern-2 holes at the front and 1 at the rear, but they're at odd spacings to aftermarket seats. Problem I have is I'd like to keep my recaro seat tilt mechanism (Seats are from a BMW e24 635csi and have a handle that you push pull to adjust the front/back seat height). These are probably the most comfortable seats I have ever sat in!
