Author Topic: Been fitting my TIP, got some sort of warning now though? HELP  (Read 5625 times)
Offline bobbarley
  • I'm kind of a big deal...
I've been fitting my Forge TIP today.  Long story short, I've connected everything up, started the car, and I get the following.  A series of beeps, then a constant ABS light on, and a flashing (!) light.
Anyone know what this is?
Offline bobbarley
Re: Been fitting my TIP, got some sort of warning now though? HELP
« Reply #1 on: 14 February 2009, 16:12 »
Also, what is this black box on the left with the pipes?  It randomly starts clicking for a while, then stops.
Offline T_J_G
« Reply #2 on: 14 February 2009, 16:33 »
The second one is your carbon canister I think and it normally clicks. Can't help with the first one though :s
Offline damo_ b
« Reply #3 on: 14 February 2009, 16:34 »
you may have disturbed your wiring on abs unit its under the airbox
horsepower sells cars
torque wins races
Offline bobbarley
« Reply #4 on: 14 February 2009, 16:36 »
Cheers damo, that might be it then, I had a right pig of a job getting the airbox in, could easily of hit something.
Offline damo_ b
« Reply #5 on: 14 February 2009, 16:47 »
hope you sort it m8
torque wins races
Offline jake
« Reply #6 on: 14 February 2009, 18:24 »
yeah when i fitted my springs last week i got that symbol on my dash,the circle with two lines either side.its ur brake sensors.if you have connected them all properly just turn the engine off remove the keys then turn it on,it should then go :smiley: :smiley:
Offline bobbarley
« Reply #7 on: 14 February 2009, 18:33 »
I didn't go anywhere near by brakes when I fitted the new TIP  :huh:
Offline K666PDP
« Reply #8 on: 14 February 2009, 19:18 »
sounds to me like u've disturbed some abs wires when u fitted ur T.I.P mate im sure it'll be an easy fix just take a gander under the bonnet it'll prob be something silly  :wink:
Offline Rhyso
« Reply #9 on: 14 February 2009, 19:21 »
+1
have you driven the car Bob?  light may go out after you've started driving  :smiley:
did you disconnect the battery before starting work?
