Author Topic: Been fitting my TIP, got some sort of warning now though? HELP  (Read 5622 times)
Offline K666PDP
Re: Been fitting my TIP, got some sort of warning now though? HELP
« Reply #10 on: 14 February 2009, 19:36 »
sounds to me like u've disturbed some abs wires when u fitted ur T.I.P mate im sure it'll be an easy fix just take a gander under the bonnet it'll prob be something silly  :wink:
+1
have you driven the car Bob?  light may go out after you've started driving  :smiley:
did you disconnect the battery before starting work?
everytime i work under the bonnet on my car i disconnect the battery 2 reasons the 1st is for safety(have seen what happens when a spanner gets dropped on a battery  :shocked: :drool:) and the other reason is it resets the ecu esp if working on engine etc, i cleaned my TB and MAF last night disconnected battery cleaned all bits left to dry refitted total time 1.5hrs took for drive now its like a new car also the engine management lights gone out   :cool: :cool: :cool:
« Last Edit: 14 February 2009, 19:38 by K666PDP »
Offline bobbarley
  • I'm kind of a big deal...
« Reply #11 on: 14 February 2009, 19:36 »
No I didn't disconnect the battery.  I had a good look under the bonnet, and can't see anything disconnected  :undecided:
Offline K666PDP
« Reply #12 on: 14 February 2009, 19:39 »
mate id disconnect the battery now for an hour or so and see if the light goes out then take the car for a drive give the ecu abit of time to 'learn' and see what happens..............defo worth a try mate...........my engine management light came on thurs i disconnected the battery cleanedthe MAF and TB and refitted now alls good and lights gone out
« Last Edit: 14 February 2009, 19:41 by K666PDP »
Offline K666PDP
« Reply #13 on: 14 February 2009, 19:42 »
mate id disconnect the battery now for an hour or so and see if the light goes out then take the car for a drive give the ecu abit of time to 'learn' and see what happens..............defo worth a try mate...........my engine management light came on thurs i disconnected the battery cleaned the MAF and TB and refitted now alls good and lights gone out
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #14 on: 14 February 2009, 19:42 »
as said just re-check your wiring/connectors under the abs unit etc as for your pic yep thats the charcol/carbon cannister for egr emissions etc it will make a clicking noise most of the time
2000 Mkiv GTi 1.8T AGU
Offline bobbarley
« Reply #15 on: 15 February 2009, 15:51 »
Thanks guys!!  I took the airbox out again today, and found a small connector that plugs into the side of the battery, kind of upside down, if you get me?  It had come loose.  Connected it up and all is good again!
New problem now though, which I will complain about in a new thread :P
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #16 on: 15 February 2009, 16:13 »
what size jubilee did you guys use on the turbo inlet join? I've fuond it a right pig to get one to fit properly...
Offline bobbarley
« Reply #17 on: 15 February 2009, 16:16 »
I got the fitting kit from DPM when I got the TIP.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #18 on: 15 February 2009, 16:38 »
Mine was already there from the SFS AUM TIP I took off. (Please see Classifieds :P).
As much as I like you Wazzer, there is NO WAY ON EARTH I'm taking it off to measure!!! :D :D
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline bobbarley
« Reply #19 on: 15 February 2009, 16:40 »
After I FINALLY got the bottom of the TIP to go onto the turbo, it was practically wedged on, no way I can ever see it coming off by accident :afro:  So hard to tighten a jubilee clip, when you're lying on your back, with your hand wedged between the dog bone mount, and the gearbox!!  :grin:
