Author Topic: suggestions?  (Read 2092 times)
Offline vwchloe
suggestions?
« on: 13 February 2009, 17:21 »
Hey, i'm going to upgrade my door speakers in my mk3, i already have 6*9 in the parcel shelf.
Do you think i should just update the front door speakers or all of them? are they 6.5" the door speakers.
not sure if its worth it?
and what kind of output, type of speaker should i go for? not going to spend too much  :wink:
any advice, I would be grateful for  :smiley:
Many Thanks
Offline tommk3cab
Re: suggestions?
« Reply #1 on: 13 February 2009, 20:06 »
just the front door speakers will be great. Unless you spend a lot of time sat ( or laid ;)) in the back of the car!
Offline Bootneck
Re: suggestions?
« Reply #2 on: 14 February 2009, 15:30 »
On a budget Fli Intergrator 6 are hard to beat,I have some in the doors of my Pissrat and they sound pretty good
Good Advise is something men give when too old to set a bad example
Offline sharki786
  • GOT BOOST??
Re: suggestions?
« Reply #3 on: 14 February 2009, 21:43 »
i had fli 6 but then i got sum jbls from uncs they gto 626e or 636e the tops is the bizz go4 jbl if u can afford it, what head unit u runnin?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline tommk3cab
Re: suggestions?
« Reply #4 on: 15 February 2009, 20:31 »
Get a HAT Legatia setup if you can afford it, or some DLS Nobeliums or iridiums.
Speaker prices range so much you would be better off setting a max budget, which will then be maxed out and more  :laugh: :laugh: :laugh:
