Author Topic: EPC  (Read 1778 times)
Offline pridders
  • Pearl Black 5 Door DSG GTI 05
EPC
« on: 11 February 2009, 21:44 »
Hi All,
A few days ago when I was driving the EPC (Engine Management) lamp came on. My immediate thought was this means ££££â€™s!! I was driving fairly slow anyway so didn’t really notice anything else other than it appeared that the boost was completely missing? I pulled over and turned the engine off waited about a minute then started it again. The light had now gone off and all was back to normal? It happened again today when I was on the M4 I was doing about 60 and the lamp came on it appeared to be ok but with just a complete lack of boost? I have revo stage 1 and I know that there can be a problem with the DV valve but when I switched the engine off and on again the EPC light goes out and boost returns and all ok again so surely it can’t be the DV valve? Any one had a similar problem? Any suggestions?
Offline bacillus
Re: EPC
« Reply #1 on: 11 February 2009, 22:05 »
Could still be a small tear in the dv.
Know anyone with a vcds to scan your car?
Without traction power is nothing!
Offline pridders
Re: EPC
« Reply #2 on: 11 February 2009, 22:16 »
Will the EPC cut in when the DV goes?
Unfortunatly I dont know anyone with vcds  :sad:
Offline bacillus
Re: EPC
« Reply #3 on: 12 February 2009, 09:34 »
Where are you based as there may be someone nearby with one who would be able help you out.
Offline revo carl
Re: EPC
« Reply #4 on: 12 February 2009, 10:14 »
epc is related to throttle etc hence Electronic Power Control
so more than likley to do with DBW, see what code is in it but for the time being dissconnect the battery (make sure you have the radio code), re-connect turn the ignition on(leave on for 30sec or so) then start the car.
this will have done a TBA which eliminates one potential factor!
Offline pridders
Re: EPC
« Reply #5 on: 12 February 2009, 10:52 »
bacillus - I am based in the Slough/Reading area
Thanks revo carl, I will try that, sorry to be a div but what is DBW?!
Also what is a TBA and by doing this what factor will this eliminate. Sorry for the stupid questions but its like having a sick child and i am one very concerned parent at the moment! Losing power when this EPC light comes on is like the GTI losing its heart!
Offline revo carl
Re: EPC
« Reply #6 on: 12 February 2009, 15:43 »
DWB= Drive By Wire
TBA= Throttle Body Alighnment
this will make sure that the trottle body alighnment and adaptaion as been done (which is an essential part of EPC system) if it's lost its adaptation values then it will throw a wobbler every now and again and will give you nothing!
Offline illyun
Re: EPC
« Reply #7 on: 12 February 2009, 19:27 »
I could have helped you out if I had my VAG-COM with me...  I'm currently working in Reading.  I'll be back next week though if you're still having issues.
Mk1 GTI Campaign, Mk5 GTI Edition 30, Mk6 GTI (Coming Soon...)
