Author Topic: Problems installing CD-changer  (Read 2341 times)
Offline golfMk2-84
« on: 01 July 2004, 00:26 »
Somebody wants to help me?  ??? :)
Have a Sony CD-Changer, but when i get it, i didnt get the voltage-cable... The only documentation to it I have, is that : 12V Negative Ground...
It is 3 connection PINs for the voltage. How do I know what is negative, positive, ground? Have a multimeter, can i use this to measure?...
And do I need a power-transformer/changer of some kind? Or do I just connect it directly to... hmm... :-\??? ?
Thank you very much for reading this at all, please answer!! :D
Greetings from Norway  ;D 8)
Sorry about the bad english  :P :'( :-\ ;D
Offline Dizzie
  • Make friends with your fast
Re:Problems installing CD-changer
« Reply #1 on: 01 July 2004, 00:44 »
last sony changer I had just had a bus cable and RCA leads. not sure what you're on about with this. maybe a pic would help?
Mk4 Golf 150PD
Offline Colin
« Reply #2 on: 27 July 2004, 16:15 »
12V negative ground means exactly that.
negative, positive, ground? you ask?
Positive is the power side of the voltage.
negative and ground are both the same thing, these are the return line for the power side back to the battery which are linked to the chassis.
If you can, take a multimeter reading from a metal part of the players internal bits to each of the three connections, one should show a link and therefore is your negative return.
That leaves you with two terminals, one of which is the positive and is usually positioned on the opposite side to the negative to avoid accidents.
Assuming the audio signal inputs elsewhere, the third will be a low wattage remote feed.
Now once you've blown this unit up, go and buy one with instructions!
hope this helps.
ps, your english is better than some peoples on here !
