Author Topic: How to identify a "90" spec fusebox  (Read 1714 times)
Offline Goops
  • mk2 gti 16v
« on: 05 February 2009, 17:43 »
Hello!
Okay, so i uderstand mk2 gti from 1990 onwards have a different fusebox.
How can I identify the earlier spec fuseboxes??
or tell the difference at a glance?
Reason is, I might be going to look at a mk2 16v for a friend.
Its a 1989 G reg and he says its a "90 spec", i know there are slight differences like the coolant tank etc
Look forward to your thougths..
Goops
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: How to identify a "90" spec fusebox
« Reply #1 on: 05 February 2009, 17:52 »
hazard switch on the steering column instead of the dash.
« Reply #2 on: 05 February 2009, 17:59 »
aye look for the hazard switch on top of the column, most other 90-spec bits can be easily chucked on, but the wiring is harder to do.
The coolant tank is another, round one = 90spec.  To convert to a 90spec tank is quite hard as you have to grind/drill the old bracket off and mount the new one in its place
Offline Goops
  • mk2 gti 16v
« Reply #3 on: 06 February 2009, 00:16 »
Cheers dudes! always  :cool:
Offline CHRIS_MC
  • GHETTO GHOLFER
« Reply #4 on: 07 February 2009, 02:28 »
hmm, why is my 89 g reg a 90 spec?
Offline Jay
  • balding fat cvnt
« Reply #5 on: 07 February 2009, 09:38 »
late '89s were '90 spec, I heard that from August '89 onwards some cars were '90 spec and some were pre-90?
Offline Khare
  • The bear that khares
« Reply #6 on: 07 February 2009, 11:49 »
correct. august 1989 was the swap to 90 spec, its 1989, but they still called them 90 spec.
Offline shakeyjake
« Reply #7 on: 07 February 2009, 12:07 »
are you 100% about that? my E reg kjet has a round exp. tank
« Reply #8 on: 07 February 2009, 14:15 »
yep positive, round only on 90 spec, square is pre-90.
As said '90 spec' actually came around in 1989, but VW would have had to work fast to get an 1989 90 spec made and shipped to the UK in time to be sold before 1990.  You also got a fair few pre-90s being registed on a G plate since they didnt sell quickly enoguh, so the line can be quite blured!
Offline krave
« Reply #9 on: 09 February 2009, 00:43 »
I have a 90 spec g reg driver that i have just vr6'd. Thought it was wierd as 90spec makes you thin 90 onwards.
