Author Topic: Converting 4x100 alloys to 5x100  (Read 2616 times)
Offline Neo Badness
  • Feet are for pedals
Re: Converting 4x100 alloys to 5x100
« Reply #10 on: 03 February 2009, 19:43 »
links not working for me :sad:
Offline filthy
« Reply #11 on: 03 February 2009, 19:53 »
Try seeing whats available for Jap cars...I know imprezas have the same PCD, the rest (centre bore, offset etc) can all be sorted by an engineering shop... :smiley:
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline JC
  • Back in the North.
« Reply #12 on: 03 February 2009, 19:58 »
gotta be an E38 member and signed in  :wink:
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #13 on: 03 February 2009, 20:14 »
chris-white that second set are the ones that have been modded from 4x100 to 5x100. i also think 17's are to big. 16's at a push maybe
Offline Neo Badness
« Reply #14 on: 03 February 2009, 21:08 »
wasn't logged in, doh... :rolleyes:
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #15 on: 03 February 2009, 21:13 »
those borbet B's are the actual sex.
« Reply #16 on: 04 February 2009, 08:40 »
just have to change hubs, caliper carriers and disks  iirc
4-5 stud bearing calipers have the ball joint fixing further forward/back, wheel end up non-central in the arch if you missmatch wishbone/bearing carrier. so wishbones may need to be fitted, possiby a different anti-roll bar depending on which bones are fitted, outer c/vs at least or shafts & track rods if track is changed etc.
« Reply #17 on: 04 February 2009, 17:43 »
im going to stick with the 5 stud less messing about
