Author Topic: front brake pads!!!???  (Read 1835 times)
Offline BlazinGTI
« on: 02 February 2009, 13:12 »
GTI went stright through its MOT today! well chuffed! anyway i had a couple of advisorys.
front b pads are low - i did the rears a few months back and it was a right arse of a job as i didnt have the correct wind back tool for the pistons - are they the same on the fronts?
also had an advisory on the front mcpherson strutt mount? do they mean the top mounts when saying this? getting some coilies in a month and was gonna change to VR6 top mounts anyway so i persume that should solve it?
cheers
Offline Adam
Re: front brake pads!!!???
« Reply #1 on: 02 February 2009, 13:43 »
Just did the fronts on sat on the GTI. It was easy ish.....soak them bolts in WD-40(or the likes) overnight.
Wheel off- two bolts at the back - clip - pads out/ pads in - reverse order. Better than the back, they can be a pain.
I used a G-clamp worked a treat. (Remember to take the lid off the brake fluid container.
Down Hill From Here.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 02 February 2009, 13:44 »
front pads don't need a windy tool.. there normal calipers, and the mount would be the top mount (why do mot testers call things by odd names?)
Offline mush
« Reply #3 on: 02 February 2009, 13:50 »
glad she passed
if you’ve done the rears you wont have any problems with the fronts. the pistons just push straight back its not like the rears with the push back twist thing.
the only problem I came across was the grub screws (they were a pain) and had to be drilled out.
just be very careful not to knock the ABS sensors.
all the best
MK2 golf 16v :-)
Offline BlazinGTI
« Reply #4 on: 02 February 2009, 14:18 »
cheers for the quick response guys!
yeah well happy it went through made the drive home in the snow even more enjoyable!!!
mush - grub screws? where are they?
also where are the ABS sensors mounted? are they pretty obvious? when i did the rears i didnt even see them?
Offline mush
« Reply #5 on: 02 February 2009, 14:28 »
mush - grub screws? where are they? = the grub screws hold the disc in place and you only need remove em if your doing the discs as well
also where are the ABS sensors mounted? are they pretty obvious?  when i did the rears i didnt even see them? = sorry should have said thats if yours has ABS
MK2 golf 16v :-)
Offline BlazinGTI
« Reply #6 on: 02 February 2009, 14:36 »
not replacing the disks so thats cool, yeah mines got abs, sure the senses are pretty obvious when you look out for them!
cheers mate
Offline mush
« Reply #7 on: 02 February 2009, 15:02 »
cheers mate
finding it hard to get a picture for you. anyway may be I've worried you for nothing if your doing the pads not sure you would even see them.
MK2 golf 16v :-)
Offline Adam
« Reply #8 on: 02 February 2009, 18:04 »
You can get a piston windy tool to push the piston back in aswell....iirc
As for the ABS pic. See the two wires going into the back of the disk? Thats the ABS.
 (stolen from gavcradd - http://www.golfgtiforum.co.uk/index.php?topic=57396.0)
« Last Edit: 02 February 2009, 18:34 by 8v8v »
  • Back in a Mk3...
« Reply #9 on: 02 February 2009, 18:33 »
I use some big plier things when doing the front!!....and swapping pads you shouldn't need to go near the abs!!
