Author Topic: Clutch gone???  (Read 1645 times)
Offline dabber77
Clutch gone???
« on: 29 January 2009, 23:10 »
Just bought my first GTI. A 16v and on the way home (obviously!) as accelerating onto the motorway in 3rd as she hit about 3.5k revs the rec counter just carried on round rather quickly but the speed didn't!!
I raised my right foot a bit the rev counter stopped at around 4k. From then on as I pressed the accelerator hard the revs grew but speed didn't. A couple of times when accelerating slowly I could hear a quiet high pitch whine.
Anyway about 80 or so miles later it started to get better and only happened if I slammed my foot down, until it stopped doing that too. On leaving the motorway I tried driving and accelerating hard throughout the gears and the problem seemed to have gone!!
I've never had a clutch go before but I'm guessing that's what's happening?  Any help appreciated?
Offline OakeyDoak16v
Re: Clutch gone???
« Reply #1 on: 29 January 2009, 23:16 »
Sounds like the clutch to me. Only gonna get worse till you replace it i should think. :smiley:
Offline muppet
  • 1.8 16v Oak Green :D
Re: Clutch gone???
« Reply #2 on: 29 January 2009, 23:21 »
ye sounds like the clutch is "slipping" had a simmilar problem to my old dears car recently and it was definatly the clutch
Offline dabber77
Re: Clutch gone???
« Reply #3 on: 29 January 2009, 23:28 »
bugger cheers guys. One of the reasons I bought it was so I can do the work myself, decided it's time to learn about these sorts of things :smiley:
Tried searching but can't seem to find a how to guide, going to buy a haynes me thinks!
Offline muppet
Re: Clutch gone???
« Reply #4 on: 29 January 2009, 23:33 »
lol good on ya mate, wish i had the balls to get that stuck in!!!!
Offline Gloves88
Re: Clutch gone???
« Reply #5 on: 29 January 2009, 23:51 »
Haynes is the way forward, dont know what I'd do with out mine...
This is pretty handy too: http://www.iol.ie/~kilkennyhockey/BentleyManual/
Offline danny_p
Re: Clutch gone???
« Reply #6 on: 30 January 2009, 00:53 »
defantly clutch going,
it's not that hard to change on a mk2  and there are a couple of ways of doing it,
a) take engine and box out do on floor and put them back in.
b) remove the gearbox from the car. remove both driveshafts gear linkages,   clutch cabel and erath strap speedo cabel ,  support enigne on jack  undo the 3 19mm bolts  the littel 10 mm sods   3 beneath and 1 at the back,  remove gearbox mount, support engine on jack  remove starter and bracket to frount mount  lower engine and waggel box out
c)  or  just remove the one driveshaft  release the 30mm hub nut on the other side,   unbolt box from engine and release engine mounts with motor suported on jack   and support box with a rope,  then lower the motor and split the box away  and change the clutch through the gap without actualy removeing box from car.
b) is probaly your best option  once you have done a few c is fastest.     a is allways an option if it just isn't happening
all the VW's have gone bar 1.
Offline dabber77
Re: Clutch gone???
« Reply #7 on: 30 January 2009, 09:35 »
cheers guys...
Danny_p thanks mate...if all else fails I can always run to work whilst she's in bits in the garage :smiley:
Offline Village Idiots
Re: Clutch gone???
« Reply #8 on: 30 January 2009, 10:00 »
Before you go to all the work of changing the clutch, check the cable adjustment. Do you have free play when the pedal is fully released? Is the biting point very high. If there is pressure through the cable because of poor adjustnent, this will cause slipping. Sometimes you can get this simply by resting your foot on the clutch pedal whilst driving. You don't do that, do you?
Like your other post also.....with cars, look for the simple things first. Don't assume disasters!!!
Offline Skiing
Re: Clutch gone???
« Reply #9 on: 30 January 2009, 14:14 »
Mine did this - clutch cable was bust - new one (the adjustable rather than self adjusting one) sorted it out.
1988 Golf GTi Mk2 16v 2.0 9a bottom end- Oak Green - 3 door - full black factory leather...
