Author Topic: Newbie Problems!  (Read 2569 times)
Offline oufcpete
Newbie Problems!
« on: 27 January 2009, 18:45 »
Evening,
I've just bought a Mk4 Golf 2.0 GTI and am experiencing some electrical problems.  The car hasn't been driven for a while and had to have a new battery so I don't know if this makes a difference.  Unfortunately, the guy I bought it off had lost the owners manual so I can't look up if any of these problems are easily resolved.  Any help would be much appreciated.
1) The stereo only seems to work intermittently. It wouldn't work when I just put the electrics on but kicked in when I started the engine. The tape and radio would then work but when I tried to put a CD in, it wouldn't read it and then when I took the CD out nothing else would work! I tried turning the engine off then on again but it still wouldn't work. Am I doing something wrong or is it faulty?
2)  I don't have the remote locking key so have to actually put the key in the door. The central locking works perfectly when locking the car but when opening only unlocks the driver door. I thought turning the electrics on would then open everything else but it doesn't until I actually press the unlock button on the inside of the door. Is this normal?
3)  I'm getting an airbag fault and airbag light is constantly on. Any ideas?
4)  The traction control light is constantly on.  I have tried pressing the ESP button but this has no effect. Any ideas?
5)  The electric wing mirrors do not seem to work at all.  Any ideas?
6)  The outside temperature gauge does not seem to be particularly sensitive as it was telling me it was 10 degrees last night! Any ideas?
7)  The trip computer doesn't seem to be working properly.  I drove for 40 miles on the motorway yesterday at approx 80mph but my average speed was apparently 13mph on Memory Position 1.  Also switching to Memory Position 2 using the little button on the steering wheel stick doesn't actually seem to change the display other than the number in the top right corner changing to a 2.  Also, on the left hand side of the screen, there is a circle with a line through it.  Any ideas?
I think that's it for now……………
Cheers!
Pete
Offline richards golf
Re: Newbie Problems!
« Reply #1 on: 27 January 2009, 18:55 »
hi
try turning key twice to unlock all the doors
Offline Dubbz
« Reply #2 on: 27 January 2009, 19:02 »
Welcome. :afro:
If you can, get it VAGcom'd which may throw up some codes which will help with your problem solving.
Try not to use the dealer as they'll pull ya pants down.  :rolleyes:
I dont know what's the cause of your problems mate, other than the key issue.^^^^
Good luck.
2002 TDI se 100bhp-ish Auto/tip Black Magic. :cool:
Offline 2.0
« Reply #3 on: 27 January 2009, 20:24 »
hello mate and welcome to the forum.
await the slating   :laugh:
im sure that the central locking only opens the drivers door on the first click it takes 2 clicks to open the passenger door, well on mine anyway, and thats with the fob . try turning the key in the lock twice in the same direction , might work might not.
2.0
Offline oufcpete
« Reply #4 on: 27 January 2009, 20:32 »
Thanks for the help guys.
With your help and asking a mate, i've managed to solve problems 2 and 5.  I'm pretty sure that my stereo problem is a loose connection as the speakers now just keep cutting in and out. I've also worked out out to operate the little computer although I'm still not sure that its readings are particularly accurate!!
Any help with the other probs would be appreciated.
Offline 2.0
« Reply #5 on: 27 January 2009, 20:51 »
care to share with me how youve fixed the mirrors ?  :nerd:
mine dont seem to work either , didnt realize until now  :smiley:
Offline richw911
« Reply #6 on: 27 January 2009, 21:00 »
The mirror must be in "o" position not L or R.  :smiley:
Offline black_mk4_golf
« Reply #7 on: 27 January 2009, 21:12 »
most easest fix   check everything before you buy the car      quite a few probs there m8 i woulda walked away  :cry:
-  Black Golf Gti 2.0 mk4  -  Private plate  -  Black Blue Colour Concept recaro leather interior  - gti badge done with a blue ' i ' to match interior  -  R32 spoiler  - 25th Anni front splitter  -  fk highsport coilovers  -   18" nouvo black diamond cut  -
Offline 2.0
« Reply #8 on: 27 January 2009, 21:15 »
Rich ???
Offline richw911
« Reply #9 on: 27 January 2009, 21:20 »
Rich ???
Forget that i miss read the post i was referring to the heated mirrors  :grin:
Fuse?
http://www.golfgtiforum.co.uk/index.php?topic=87372.0
