Author Topic: ARB  (Read 4464 times)
Offline jonnyturbo
ARB
« on: 27 January 2009, 14:15 »
ok ppl what anti roll bars are you running with. I need a front one as driveshaft rubs arb as its lowered 50mm. So may aswell replace front and get a rear one while i am on lol
Offline Rhyso
Re: ARB
« Reply #1 on: 27 January 2009, 14:18 »
Neuspeed
Whiteline
Eibach
to name a few
i'm running the Whiteline Adjustable rear on mine - improves things no end  :smiley:
don't forget that ideally you don't want a thicker roll bar at the front than what you have without fitting one at the rear otherwise you'll INCREASE the understeer
Offline Damian @ DPM
  • DPM Performance
Re: ARB
« Reply #2 on: 27 January 2009, 14:21 »
If you're wanting both front and rear i'd say go for the Eibach 25/25mm kit, makes a massive difference and it's really good value for money.
http://www.dpmperformance.co.uk/eibach-25mm-front-25mm-rear-arbs-golf-4-0797-p-13.html
Damian @ DPM
DPM PERFORMANCE
The premier online suspension and handling specialists!
0191 2816844
sales@dpmperformance.co.uk
http://www.facebook.com/pages/DPM-Performance/208281640681
Offline jonnyturbo
Re: ARB
« Reply #3 on: 27 January 2009, 14:34 »
cheers rich. Where u get ur whiteline 1 from?. U just got it attacthed to your normal shocks at rear. Or you got new shocks on rear
Offline Rhyso
Re: ARB
« Reply #4 on: 27 January 2009, 14:40 »
whose Rich?  :huh:
i got the whiteline from the Balance Motorsport
it just attached to the rear shocks
Offline the_stink
  • A3 140 TDI
Re: ARB
« Reply #5 on: 27 January 2009, 14:43 »
is it advisable to upgrade both the front and rear? or can you just do for example the rear
Offline Rhyso
Re: ARB
« Reply #6 on: 27 January 2009, 14:49 »
i've only done the rear - helps REDUCE the understeer which is what you want ideally - give you a more neutral balance
Offline redevo1
  • golt gti 1.8t AGU
Re: ARB
« Reply #7 on: 27 January 2009, 14:52 »
Looks to sit really low do you have clearance issues with speed bumps?
God I've got a golf I'm getting old!Full Recaro leather with arse waming seats, the reason for buying a Golf!Spec: R tech remap:Eibach Fr+Rr ARB:Powerflex ARB bushes:Forge BOF DV:Silicone TIP:Induction kit:Jamex suspension:312mm big brake setup: EBC pads F+R:Vr6/g60 clutch:5mm-fr+15mm-rr spacers: Anni front & rear Valances & Anni rear roof spoiler: Silicone hose boost/Breather kit.
Offline Rhyso
Re: ARB
« Reply #8 on: 27 January 2009, 14:55 »
none and that pics was taken before i had it lowered it 30mm  :smiley:
only issue is if i have to park up on the pavement but if i'm careful i avoid scraping it - only done it once
  • DPM Performance
Re: ARB
« Reply #9 on: 27 January 2009, 15:04 »
A lot of people just do the rear as that gives the most improvement as the Golf 4 FWD doesn't have one as standard.
A lot of people go for the Eibach over the Whiteline as it attaches directly to the bottom of the shock so doesn't hang nearly as low as the Whiteline. Can't beat the Whiteline for value though.
Damian @ DPM
DPM PERFORMANCE
0191 2816844
