Author Topic: ARB  (Read 4471 times)
Offline K666PDP
Re: ARB
« Reply #10 on: 27 January 2009, 15:05 »
cheers rich. Where u get ur whiteline 1 from?. U just got it attacthed to your normal shocks at rear. Or you got new shocks on rear
whose Rich?  :huh:
i got the whiteline from the Balance Motorsport
it just attached to the rear shocks
look how sooty those tailpipes are  :grin: :grin: :grin:
w0ffle
Re: ARB
« Reply #11 on: 27 January 2009, 15:14 »
Looks easy to fit, perhap this should be next on my list.
Offline Ridg
  • TDI - Soot Happens!
Re: ARB
« Reply #12 on: 27 January 2009, 15:49 »
Rhyso or anyone else that's fitted one, does anything need to be drilled to fit them or are all the holes already there?
Offline Rhyso
Re: ARB
« Reply #13 on: 27 January 2009, 15:53 »
nothing needs to be drilled - you use the existing shock bolt (or one maybe provided - can't remember) and push through the droplinks and then tighten up  :smiley:
Dave fitted mine in less than 30 minutes
Offline Ridg
Re: ARB
« Reply #14 on: 27 January 2009, 16:00 »
something for the spring time me thinks then :afro:
Offline Rhyso
Re: ARB
« Reply #15 on: 27 January 2009, 16:07 »
definietly - £ for £ i think its the best value mod you can do to the MKIV along with a remap :afro:
Offline Ridg
Re: ARB
« Reply #16 on: 27 January 2009, 16:11 »
i don't really abuse mine on the B roads, so would say cruise is my best £ for £ mod
Offline dai-cymru
  • 1989 MK2 16V
Re: ARB
« Reply #17 on: 27 January 2009, 16:13 »
what a handsome fella in blue overalls
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: ARB
« Reply #18 on: 27 January 2009, 19:01 »
Neuspeed
Whiteline
Eibach
to name a few
i'm running the Whiteline Adjustable rear on mine - improves things no end  :smiley:
don't forget that ideally you don't want a thicker roll bar at the front than what you have without fitting one at the rear otherwise you'll INCREASE the understeer
This is my feeling too.  Although most kits you buy as a set, seem to come with a thicker front ARB than the rear!! :huh:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Re: ARB
« Reply #19 on: 27 January 2009, 19:03 »
More like "Thank God he's facing AWAY from the camera", LOL!!!  :D
