Author Topic: Handbrake light  (Read 1556 times)
Offline tnewson
Handbrake light
« on: 26 January 2009, 21:44 »
Hello,
I've noticed that over the last couple of days my handbrake light comes on under hard acceleration. It like flashes on and off. Its the  red light with ' ! ' In the middle. Is this just a handbrake light or is it a general ' stop kaning me ' light?
tom
Offline Khare
  • The bear that khares
Re: Handbrake light
« Reply #1 on: 26 January 2009, 22:28 »
shift light :grin:
Offline nealey
Re: Handbrake light
« Reply #2 on: 27 January 2009, 00:21 »
First port of call check the fluid level, if its low top it up and check for leaks and make sure the brake pads aren't excessively worn
Offline Gareth
Re: Handbrake light
« Reply #3 on: 27 January 2009, 01:25 »
is the brake fluid low?
Offline Mew
Re: Handbrake light
« Reply #4 on: 27 January 2009, 13:54 »
It'll just be the handbrake switch i'd imagine. Take the plastic surround from the base of the lever and you'll see the push switch. Just make sure its secure, or if worn then replace it
Offline AudiA8Quattro
Re: Handbrake light
« Reply #5 on: 27 January 2009, 19:05 »
Brake fluid reservoir level sensor on cap, very common fault. Worth a look.
sharpie
Re: Handbrake light
« Reply #6 on: 27 January 2009, 19:35 »
go with this.
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Handbrake light
« Reply #7 on: 27 January 2009, 19:46 »
shift light :grin:
 :grin: :grin: :grin:
Seriously though, I would check the fluid level first as it's the easiest thing to check. Then look at the handbrake light switch if the fluid level is ok.
Offline tnewson
Re: Handbrake light
« Reply #8 on: 27 January 2009, 21:56 »
Cool,
Will do! Cheers for your help!
