Author Topic: Interior Wiring removal?  (Read 1010 times)
Offline k4ith
« on: 25 January 2009, 19:50 »
Things go from bad to worse the more i move about the car. My queiry is this I have the interior out and between the rear seats and the boot on the drivers side there is a large black circular bit of metal with wiring disappearing underneath now iam sure on another golf i have seen the same thing but minus the wiring, so whats the wiring for and can it be relocated? thanks in advance.
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline AdamMk2
  • Beautiful
Re: Interior Wiring removal?
« Reply #1 on: 25 January 2009, 19:52 »
mate that will be your fuel pump!!  :laugh:
Offline k4ith
« Reply #2 on: 25 January 2009, 21:53 »
Aye?
I couldn't find anything in the Haines manual for it, so didnt take the cover off so thr wiring needs to stay then :laugh:
Offline Ben Lessani
« Reply #3 on: 25 January 2009, 22:00 »
Yeah, 3 screws, its for the lift pump in the fuel tank. There should be 3 wires going to it IIRC, the fuel pump ground, 12v and gauge resistance wire.
You can route them elsewhere pretty easily if you want to, along the floorpan outside then up underneath the fuel tank, easy peasy.
You'll need to armour the cable and make sure its water tight, check this place out http://www.vehicle-wiring-products.eu/ for good quality wiring bits.
