Author Topic: 1.8T Dash Message : STOP! CHECK COOLANT SERVICE MANUAL  (Read 3490 times)
Offline snowfiend
Got a problem with my 1.8T.....only had it a week and driven it twice  :embarassed:
I turned the engine on and got three beeps followed by 'STOP! CHECK COOLANT SERVICE MANUAL' message on the dash.
The message goes straight away and doesn't re-appear whilst driving, only on start up.
The car seems fine, doesn't seem to be over heating. I took the car for a steady drive of about 10-15 miles keeping a steady eye on the temp gauge and it never went above 90 degrees.
Brought the car back home, turned the engine off and let it cool down a bit.  Turned it on again on the drive and it's not showing the message anymore !?!
I've checked the coolant level and it seems to be sitting in-between MIN & MAX in the expansion globe/bottle so that looks ok to me.
What temp does the Rad fan normally kick in ?  Cant say I heard the fan working whilst driving but to be honest I wasn't listening out for it.
I wanted to check the fuses incase the Rad fan isn't working but cant seem to work out which one it should be....I thought F16 but that doesn't appear to be a working fuse socket on my car (ie: no internals)
Any ideas ?
Offline dai-cymru
  • 1989 MK2 16V
Re: 1.8T Dash Message : STOP! CHECK COOLANT SERVICE MANUAL
« Reply #1 on: 25 January 2009, 16:14 »
the fan wont come in at these temps unless your driving very hard gauge should sit at 90
i expect you need a new coolant expansion bottle quiet common failure as the level sender is in the bottle. about a tenner i think for a new one
Offline Rhyso
« Reply #2 on: 25 January 2009, 16:19 »
Dai is correct - the sensor does fail and a new bottle is £9.32 part no 1JO 121 403 B  :nerd:
Offline snowfiend
« Reply #3 on: 25 January 2009, 16:22 »
Thanks chaps  :smiley:
Will try and order one online now.
Assume it's ok to drive the car in the meantime yeah ?
Offline Rhyso
« Reply #4 on: 25 January 2009, 16:24 »
cheaper from the dealer unless you pick it up for a fiver lol
shoud be fine seeing as you got the correct amount of fluid - its only the sensor thats playing up; if you had lost coolant then i'd look for leaks etc
Offline Miggie
  • Golf I II III IV and perhaps V soon
« Reply #5 on: 26 January 2009, 06:56 »
This happened to me but when getting the coolant to max level it never happened again.. :cool:
R-tech Agu k03s power!!
Offline JamieGTi
« Reply #6 on: 26 January 2009, 09:14 »
This happened to me the day I got mine!
It was a new water pump required, £300 job  :sad:
Parts are cheap but labour is a p*ss take because of its location
