Author Topic: 1600 into 1300 will it go?  (Read 5534 times)
Offline oldngrey
« on: 24 January 2009, 14:11 »
Hi,
My son's 1300 is causing problems. Head's been off and skimmed to have a new head gasket fitted, after reassembly garage says there is interference when engine is turned over by hand. They suggest that the head had already been skimmed and now valves are touching piston heads. Any (polite) suggestions please folks? Also I have heard of a 1600 engine nearby would this fit? Cheers for any ideas, Rich
Offline sidecarphil
Re: 1600 into 1300 will it go?
« Reply #1 on: 24 January 2009, 14:24 »
you can get the top of the valves milled off a little
this will stop the interferance
head will need to be off again though
 :cry:
dont know about 1.6
Offline Khare
  • The bear that khares
« Reply #2 on: 24 January 2009, 15:33 »
1.6 wont fit in because the 1.3 and the 1.6 have different engine mounting locations.
Offline Jay
  • balding fat cvnt
« Reply #3 on: 24 January 2009, 17:55 »
It WILL fit. You just have to make it fit, if that means a 1.6 sub frame, wishbones etc etc so be it.
Might have to change fuel lines too.
Offline Khare
« Reply #4 on: 24 January 2009, 17:57 »
a jet engine will also fit a mk2 if you make it fit. all im saying is aint not worth putting a 1.6 into a 1.3. Just buy a 1.6.
« Reply #5 on: 24 January 2009, 18:53 »
what are you 2 on about :grin:
1.6 will drop right in on the existing engine mounts, just need the correct engine brackets on the block, and the gearbox to go with it.  Main issue is the exhaust, plus the carb wiring will need a bit of jiggery.
Offline JC
  • Back in the North.
« Reply #6 on: 24 January 2009, 18:57 »
Gotta love people giving advice when they aint got a clue  :laugh:
Offline MooZ
« Reply #7 on: 24 January 2009, 19:00 »
1.6 subframe? Lol
Lifes a beach!
so you may aswell die in a nice Bikini!
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #8 on: 24 January 2009, 19:03 »
Surely not?!!
 :grin:
Offline Khare
« Reply #9 on: 24 January 2009, 19:06 »
1.3 has mounting on the side next to the cambelt. 1.6 has in at the rear of the engine. It CAN fit but it needs major work.
