Author Topic: intermittent fault  (Read 2138 times)
Offline carloscdt
intermittent fault
« on: 24 June 2004, 13:16 »
8V Mk2 GTI 170K
I have an intermittent fault where if i am sitting at about 3000 rpm
5th or 4th gear and I ease off the accelerator and go into overrun, the car jerks violently as though the accelerator is being stamped on and off quickly. If I then go to accelerate there is no response for about a second then the car picks up and goes??
Coupled with this I have noticed if I drop out of gear while travelling the revs are racing about between 1000 and 3000 or sit constantly at about 2800, then gradually die down to tick over!!
Whats the problem and are the 2 symptons linked.
Any help greatly appreciated .
Carlos ???
Offline Gambit
Re:intermittent fault
« Reply #1 on: 24 June 2004, 13:56 »
is it a K-jet or Digifart?
Offline carloscdt
« Reply #2 on: 24 June 2004, 14:02 »
87 digifant  PB engine code
Mixologist
« Reply #3 on: 24 June 2004, 18:15 »
check your ht leads spark plugs rotor arm and distributor, also check all vacuum and air lines and your throttle valve switches.
this is actually veedubgti8v but i cant be arsed to sign out
Offline carloscdt
« Reply #4 on: 25 June 2004, 08:51 »
thanks for reply.
was due to do service this weekend any way,
just wanted to see if there was anything specific
that anybody had come across that I could check.
Carlos
