Author Topic: more ampage!!  (Read 1829 times)
Offline TimMan
more ampage!!
« on: 22 January 2009, 22:42 »
My head unit has one pre out, i am running the amp for my sub from this. What is the best way to run more amp, as i want to amp my component speakers in the front?
Cheers.
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: more ampage!!
« Reply #1 on: 23 January 2009, 09:06 »
3 options:
1) Change the head unit to give you more than 1 pair of pre-outs. 3 is best, a front pair, a rear pair and a non-fading (for sub) pair. This is obviously the most expensive (but best solution)
2) Use an rca signal splitter. Very cheap - you'll do this for under a tenner. these essentially sit somewhere along your RCA cables (either at head unit end or amplifier end) and create two more RCA sockets/plugs (dependant which type you buy). Very littel signal loss. The only problem is, your fading will be a little messed up - the likelihood is that your current pre-out is a rear pre-out (most single pre-outs are) if you utilise this then you'll loose the ability to fade properly because everything will be driven from rear-based signals. The solution here is to swap your headunit-amplified cables over, so the front out puts of your head unit power your rear-fill speakers (if you have them) your fader will then work back to front, fading to the front will quieten amps and increase volume to rear fill speakers, moving to the back will quieten the rear fills and make amplified speakers (sub and front components) louder.
3) Use a line to rca converter. This little box of tricks will take an amplified signal (i.e. speakers wires) from your headunit and turn it into a pre-out. This means that you retain the fading abaility (as you'd use the front speakers outputs from your headunit). The downside is that, because this box of tricks is taking an amplified signal and converting it, the signal out the other end isn't as clean as a true pre-out signal.
You pays your money, you takes your choice!
The greatest leveller of them all - the Carousel
Offline Dan34
  • VTEC Powerzzzz
Re: more ampage!!
« Reply #2 on: 23 January 2009, 18:26 »
great advice there! :smiley: but i wouldnt go with option 3 i tried it and was pants to be fair, i would go for new head unit maybe more expensive but in the long run it will be more beneficial
Dan
Offline sharki786
  • GOT BOOST??
Re: more ampage!!
« Reply #3 on: 23 January 2009, 19:15 »
ur amp might have a pre out to add another amp for you speakers. have a look at it.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline S11EPS
Re: more ampage!!
« Reply #4 on: 23 January 2009, 23:17 »
Good point (although I assued the OP had already looked to see if he could daisy chain amps together)
This will get you up and running, no doubt, but you will still have fading issues (if your headunit pre-out is rear, which I'd bet it is)
Offline TimMan
Re: more ampage!!
« Reply #5 on: 24 January 2009, 09:08 »
Lot's of help, thanks.
Option 2 for me though, there is now way she will let me buy a flash headunit at the moment,   :laugh:
