Author Topic: Flat spot, rolling road?  (Read 4003 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 23 June 2004, 12:40 »
Hi all, my mK2 16v has a flat spot in the low revs, would it be best to get it on a rolling road to find the problem?
If so how much on average is a rolling road test? and anyone know of a good one in Swansea, south wales?
Also what checks can be done first to find the flat spot, I am guessing it could be a number of things.
Offline Gambit
Re:Flat spot, rolling road?
« Reply #1 on: 23 June 2004, 13:13 »
explain your flat spot? where abouts does it come in on the rev counter.
16v's you need to keep the revs pretty high otherwise they bog down
rolling road will address all your problems
your looking at paying ?40per hour to get it setup on a rolling road
Offline Deefadog
« Reply #2 on: 23 June 2004, 14:41 »
The flat spot comes in straight away as i am pulling away, like a cough/stutter then the engine just pulls great, i have not really tested this fully, because I have just had all my gear linkage changed, as i had no first gear :)
I'll test the car out tomorrow and let you know exact revs etc
Veedubgt18v
« Reply #3 on: 23 June 2004, 17:14 »
check all your vacuum connections and air intake connections, could be a loose pipe causing crap running. also check the idle speed etc are set right and that your ht leads etc are sparking strong and that your engine is timed properly
Offline Deefadog
« Reply #4 on: 24 June 2004, 08:36 »
Thanks, i'll check them all out and let you know, I may take it to a crypton tunning place first, costs about ?30 but hould find the problem, and may find other probs I don't yet know about!
Offline Gambit
« Reply #5 on: 24 June 2004, 13:48 »
you aint got a flat spot then
dont be takin it to a crypton tuning person either, take it to a VW specialist and ask them to set the timing & CO on it, (basically a tune-up) it'll cost the same if not less than letting a crypton tuning plank at it
« Last Edit: 24 June 2004, 13:50 by Gambit »
Offline Deefadog
« Reply #6 on: 24 June 2004, 23:06 »
Gambit, what do you mean when yoy say I have not got a flat spot? I have noticed that anything above 2 and half revs is fine, below that is crap! in any gear, well first and second :)
Offline Deefadog
« Reply #7 on: 01 July 2004, 12:40 »
Update. getting the car back today :)
It was the distributor head, the seals had gone and was leaking oil.  I have not got it back yet, so have not tested it.
Parts cost ?140, labour ?40!
Sound a fair price?
Offline Gambit
« Reply #8 on: 01 July 2004, 13:47 »
?140 for a seal?? or did they replace the whole distributor?
you can buy replacment seals for your existing dizzy. also, make sure you get the old dizzy back
even so that is still expensive, i got a new bosch 16v dizzy from EuroCarParts for ?80
and ?40 labour!! the dizzy is held in by two bolts, and then you just set the timing
bout 15mins work
Offline Deefadog
« Reply #9 on: 01 July 2004, 14:10 »
That was for a new distributor unit, cap and rotor arm.  Labour was in fact ?30, but he did do a few checks on it for me also.
Just had the car back and it is finally running nice.
he advised to get a new Ignition  lead also, is this expensive?
Also he advised the engine was burning oil! But I have seen no evidence of this, what could be the worst case senario for buring oil? and what is the cheap one :)
Thanks
