Author Topic: Flat spot, rolling road?  (Read 3998 times)
Offline Gambit
Re:Flat spot, rolling road?
« Reply #10 on: 01 July 2004, 15:31 »
well you where a bit hard done by on the dizzy and labour but not to worry, at least its running now
if your burning oil then
best case scenario
blocked breathers - clean them all out
the current oil is too thin, you should use 15w40 semi-synthetic oil in it
worst case scenario
worn piston rings - get a compression test done, then get a wet compression test - this will tell you if its rings or valves
plan of attack
clean out the breathers & get an oil change.
if it still burns oil then get the compression test done
« Last Edit: 01 July 2004, 15:32 by Gambit »
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #11 on: 02 July 2004, 08:00 »
Yeah think i was done a bit :( On the bill he said for parts that the dizzy head unit was ?164.40 Incl VAT!
I'll check this today at my local VW spares, and if it is lower I know not to go back there!
Thanks for the good advice mate, I check these things out! Just for the time being I need to top up the oil can I use 15w40 semi-synthetic oil if the previous owner used non-synthetic, can I mix them?
Offline Gambit
« Reply #12 on: 02 July 2004, 10:36 »
yeah you can mix them buts its just as handy to do an oil change rather than top it up
your talking 10mins work in an oil change
ask stuart in EuroCarParts for a price on a 16v dizzy (ask him for full price and exchange unit price)
if you didnt get your old dizzy back then i bet the garage got an exchange price!!
Offline Deefadog
« Reply #13 on: 02 July 2004, 16:37 »
Just got a price from local VW dealers, price was ?84.
I will not be going back to that garage, funny thing is that its a friends brother in law, so i thought He would see me good, looks like he saw himself good instead!
When you mentioned the "blocked breathers - clean them all out"
Where are these breathers? I have looked through my haynes, but can't find them :(
Thanks again
Offline Deefadog
« Reply #14 on: 04 July 2004, 20:49 »
^Bump^ :)
golfvr6
« Reply #15 on: 04 July 2004, 22:10 »
A complete distributor from VW for 84 quid?
Last time i asked it was about 130 quid.
Have prices dropped that much?
Offline Deefadog
« Reply #16 on: 05 July 2004, 08:45 »
I ask vw for a distributor head! maybe it's different and I did not get done to much?
Anyone know where these -  blocked breathers are?
Also the car was blowing no smoke before this job was done, could this new distributor cause the smoke?  I have been running normal unleaded in it though instead of Optimax which was put in it all the time before, could this cause the smoke also?
Thanks
Offline Gambit
« Reply #17 on: 06 July 2004, 14:11 »
if you are running unleaded instead of Optimax then there is a fair chance the timing is out also
