Author Topic: ABF spluttering  (Read 5286 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: ABF spluttering
« Reply #10 on: 30 January 2009, 18:22 »
Yep vacume hose is connected. Whats this MAP?
heres that pic of the lambda
4 branch is then straight after the flexi joint
Offline Conker
Re: ABF spluttering
« Reply #11 on: 30 January 2009, 18:27 »
Got a photo of that lambda install?
It sounds like your asking for niche porn...
I imagine you to be rubbing your thighs "Vic Reves stylee" whilst asking that.
Re: ABF spluttering
« Reply #12 on: 30 January 2009, 18:31 »
lol   :grin: i see what you mean really im not!  :embarassed:
Offline Conker
Re: ABF spluttering
« Reply #13 on: 30 January 2009, 18:33 »
Eh?  You didn't say it. Wasn't it DH?
Re: ABF spluttering
« Reply #14 on: 30 January 2009, 18:42 »
oh good
Offline danny_p
Re: ABF spluttering
« Reply #15 on: 30 January 2009, 19:21 »
MAP  has braded hose on the original install its 110cm long  goes from TB  or comes off the vaccume pipe for the brake servo ( before the 1 way valve )
HC  really shoudl be very low
all the VW's have gone bar 1.
Re: ABF spluttering
« Reply #16 on: 31 January 2009, 10:27 »
^ if that description doesnt hep, the map senor is in the ECU. theres a nipple in the side of it that needs hooking up to vacuum ;)
Re: ABF spluttering
« Reply #17 on: 31 January 2009, 18:58 »
Took it to someone to have a look at today, hes rather baffled too and couldn't believe how bad the flat spot was. went on the motorway to get there big mistake couldn't get above 55mph so had to come off at the first junction. Danny p you know that green and red wire we spoke about is this deffinatly in the right place. (ECU pin 7 which is the ignition switch start signal).
Also I had to cut this wire bellow to remove loom from the toledo not sure whether its related?
F
1 - Red/blk- starter motor pin 50
\- red - starter/inhibator & reverse switch pin 1 (A/T)
4 - brn - earth (location 85)
5 - red/grn- Digifant ECU pin 1
6 - blk/red- reverse light switch (M/T) or starter/inhibator & reverse switch pin 6 (A/T) (fuse #14)
7 - blk/blu- reverse light switch (M/T) or starter/inhibator & reverse switch pin 2 (A/T)
9 - grn - TCI Unit (US 9a 2.0 16V MK2
MAP is all connected even changed the fuel pump today and re-checked the timing no change  :sad:
Offline danny_p
Re: ABF spluttering
« Reply #18 on: 31 January 2009, 19:47 »
is the rev counter bounceing around ?
fuel lines defantly the right way round ?
Offline DarnPB
  • Formerly Darnpistonbroke
Re: ABF spluttering
« Reply #19 on: 31 January 2009, 19:52 »
Could the fuel 'return to tank' pipe be kinked or blocked, preventing the fuel from returning and thus over fuelling the engine? I don't know much about Kjet yet, so it's just a thought. If the engine has been swapped, then maybe a pipe got damaged in the process. :undecided:
