Hi all
I havent got a GTI yet, but am very interested in getting one around May/June of this year. I'd like a MK5 model, maybe around £12-13k to spend.
Anyways, Im still thinking about whether I would want DSG or not. Obviously its quite a breakthrough, and the fact that the car is faster is quite obvious given the fact that you lose no momentum when changing gear etc and with 'Launch Control'. However, Im still a little confused and have a few questions. I would be very grateful for any replies. Ive been browsing the forum for a while and have the jist about DSG, but still have many questions....Im not looking for an arguement about why manual is better, or why DSG is better, since we've had that in another thread already. Im just after a better understanding of DSG overall....
Here I go.....
Automatic1. When in auto mode, Im assuming the gears change quite early in the revs? Hence you should be able to get better MPG? Am I correct in assuming this? If so it would be perfect since I could use that to get to work and back, then shift it into manual for when I want some fun!
Manual2. When using manual, I understand you can shift up/down with the Gear Knob, or the paddles (if you have them). However, is it true that if you reach the 'redline' on the revs, the car shifts up for you anyway?
3. Does the dash display the current gear you are in?
4. If you are traveling in 4th Gear, and you come to a 2nd Gear corner, as you brake do you have to shift down or does the car shift down automatically as you brake? If you need to shift down yourself, does the car jolt as you shift down to a lower gear which doesnt match the revs?
5. Ive heard talk of the car jolting, and not being smooth, when using the manual transmission in lower gears - is this correct? If so, why does this happen and can it be corrected by the driver?
6. When changing up a gear, do you need to remove your foot from the accelerator, and then put your foot down again - as you would if you had a clutch pedal - or do you just keep your foot where it is and not release the pedel at all?
7. Is it correct that when in manual you cant change gear while turning, say around a roundabout, for example?
Sport8. So in this mode, the car is in automatic tranny, but takes the revs to the highest point between each gear change?
9. Why would someone use this over the manual mode in that case? Since even with manual if you reach the top rev, it will shift up for you - just as sport does?!
Launch Control10. I understand you can use this with both Sport and Manual tranny modes - what happens if you use Launch Control with ESP still on?
11. When in sport or manual, by keeping your foot on the brake, bringing the car to 2400rpm, then letting go of the brake, do you automatically use Launch Control, or is there some other button etc to be pressed to inform the car you want to 'launch'?
Overall12. When changing between manual/auto/sport modes, do you need to bring the car to a stop, or can you change even while the car is moving?
Sorry for so many questions, but I want to fully understand DSG before I either get it, or rule it out.
The added bonus is that the wife only drives auto cars, so she could drive it as well - if I ever let her (although its a good arguement in convincing her that we want a GTI
) Although Im concerned that not having a manual will take all the fun away from driving, and make driving 'boring'.......
