Author Topic: Smoke on idle  (Read 2412 times)
Offline Chrisb
Smoke on idle
« on: 22 June 2004, 11:39 »
Hello got a Problem with my 1990 8v gti, i was giving it a bit of a thrashing on my way to see my girlfriend, then when i was at hers openin the gates i noticed black smoke coming out of the exhaust on tick over  ???
its gone off since then but stinks all the time now
any ideas what ive done?
Chris
Offline davidhawkins_78
  • Valver Bad Boy
Re:Smoke on idle
« Reply #1 on: 22 June 2004, 12:26 »
Black smoke sounds like carbon being burn't off matey - was there any hint of blue in the colour ???
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline Chrisb
Re:Smoke on idle
« Reply #2 on: 22 June 2004, 12:37 »
nah didnt seem to be just a steady flow of black smoke  ???
parked it up for a week or so after that, been driving it for a few days now and no smoke just nasty old car smell :(
Offline Tufty
Re:Smoke on idle
« Reply #3 on: 22 June 2004, 14:38 »
r u sure theres no sign of a clear/blue hint of smoke cus ur motor cud b like mine and b burning some oil and the smell of is certainly nasty
Offline Chrisb
Re:Smoke on idle
« Reply #4 on: 22 June 2004, 14:48 »
no, no blue thats what i thougth at first maybe the oil seals had gone or something but its fine now, just stinks, only done 100k miles which is nothing to an 8v engine  ???
Offline Tufty
Re:Smoke on idle
« Reply #5 on: 22 June 2004, 15:04 »
thats very true mate 100k is noting to them mine has 180k and its still goin strong apart from burning the odd bitta oil its all good. chris check ur head gasket for n e wee oil leaks cus they could b where the nasty smell is coming from bits of oil cud b dropin down onto ur inlet manifold and burnin
Offline Gambit
Re:Smoke on idle
« Reply #6 on: 22 June 2004, 15:06 »
probably just carbon burning off
if anything run it up to normal temp, then stand at the back while someone tramps on & off the accelerator
only other thing that springs to mind is that its overfuelling
Offline Chrisb
Re:Smoke on idle
« Reply #7 on: 22 June 2004, 15:39 »
that was also one of my thoughts over fueling but there was too much smoke for it to be that i think, will have another check for oil leaks everywhere, just put a new sump and new rocker gasket on when i got it, maybe i have managed to get the cork twisted on the rocker cover
cheers for the replies :)
Offline Wolf
Re:Smoke on idle
« Reply #8 on: 23 July 2004, 13:15 »
Valve stems and oil seals are worn ...a common problem.  :-\
