Author Topic: sidecarphil - Edition One  (Read 24791 times)
Offline jv
  • Administrator
« on: 17 January 2009, 11:52 »
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline sidecarphil
Re: sidecarphil - Edition One
« Reply #1 on: 17 January 2009, 17:25 »
hi there and welcome to my project car
it was bought as i needed a car for winter in holland as i only had my ZXR750L1
but i changed my mind as i liked it so much
so here we go , this is the day i picked it up
it was seen on marktplaats (dutch ebay) , listed as good general condition but oil light coming on
these are the pictures i took the day we looked at it
« Last Edit: 17 January 2009, 18:04 by sidecarphil »
Offline sidecarphil
« Reply #2 on: 17 January 2009, 18:08 »
then i got it home and gave it a dam good clean up and service
The oil light was coming on when the engine was hot , and more when i was cornering
so i changed the oil and filter with a genuine filter and good quality 10w40 oil
and i also saw this  :shocked: :shocked:
so i removed the sump and with a few tap's with a LARGE hammer and we were sorted
Offline sidecarphil
« Reply #3 on: 17 January 2009, 18:16 »
then the clutch went  :angry: :angry:
so i changed it with an LUK item , changed the oil again as it was really bad
BUT THEN
disaster hit ,
the earth wire to the gearbox had snapped inside the shrouding  :angry: :angry:
this then fried the ECU , but it took me about a week to find this
thanks to every one on here who helped me with this problem .
a new one was sourced from the USA as my car has a lambda probe
fitted and we were off again  :cool: :cool:
i also fitted some new front tyres as they were getting low
but i have had a wheel wobble ever since i have owned the car , but i've not been able to trace it as of yet  :angry:
Offline sidecarphil
« Reply #4 on: 17 January 2009, 18:26 »
well i've sort of got out of sync with all the work i've done so here is what i've got up too
changed the rear light's to red/clear with supercharged Range Rover indicator bulbs (blue but flash orange)
fitted the black/red ones to the Mrs' 1.3 :)
then i changed all the front lights to crystal ones and matching indicators ,and made an uprated wiring loom with 2relay's( this will be transfered to the Mrs' little 1.3 when i upgrade to HID)
the indicators were fitted with  supercharged Range Rover indicator bulbs (i love these , better than silvertec poop)
Offline sidecarphil
« Reply #5 on: 17 January 2009, 18:47 »
happy motoring for a couple of months
then disaster again
when the car got warm it was stuttering coughing and was soo rich
i was down to 200 km per tank of fuel  :shocked: :shocked:
so changed the blue cooling sensor , airflow meter , coil , lead's, dissy cap , rotor arm , ign amplifier
but still nothing sorted
so i started proper diagnosis with a multimeter and all  :shocked:
i stupidly left the ECU to the last as it was new !!!!!
but it turned out the plastic cover above it had a nice little crack in it letting water drip onto the connector !!
green wires , so i stripped the connector cleaned every pin , and refitted with a fixed cover
but the problem was still there i little bit
i had a 4 branch manifold to fit with a new (quieter) exhaust as the one on the car was a single box LOUD one !!
as i was fitting the 4 branch i noticed the lambda probe was rattling  :rolleyes: :rolleyes:
problem found , new lambda fitted and oooooh yeah we off again
but i have now got problems with the backbox rattling on the rear beam  :angry: :angry:
it appears the back box is for a 16v modded to fit the rest of the system (not well)
so i think i will upgrade to a stainless system from a 16v as i love the look of the 2 square tailpipes
Offline sidecarphil
« Reply #6 on: 17 January 2009, 18:58 »
well we went to the nurburgring over the weekend as i was visiting a friend in a german hospital after a serious sidecar racing crash which lead to the death of my good friend Steve Norbury R.I.P mate
but this uncovered a few problems with the brakes ................... they are poop
« Last Edit: 17 January 2009, 19:01 by sidecarphil »
Offline sidecarphil
« Reply #7 on: 17 January 2009, 19:11 »
just a couple of nice pictures i have taken in the winter
« Last Edit: 17 January 2009, 19:15 by sidecarphil »
Offline sidecarphil
« Reply #8 on: 17 January 2009, 19:12 »
well after the trip to the nurburgring i decided to upgrade the brakes and after a little bit of digging and reading on here i decided that i would buy some 280mm G60 front brakes
old poop little 239mm ones (will be fitted to the Mrs' 1.3)
shiney new G60 280mm front set up with painted calipers
old V new
i had a problem fitting these as the left drive shaft was stuck in the hub  :angry:
so i removed it and pressed it out , as i was at work and had all i needed
this also lead me to find the problem with the wheel wobble
the inner joint's grease was like tar and it didn't move nicely if at all so i stripped it claened it and added some new grease , wobble gone PHEW
painted the rear calipers too
i checked before i fitted it all that the wheels would clear the calipers but i didn't realise how close it was till i saw this
but they look cool behind the wheels
i just need a 22mm master cylinder as the peddle seems to move a long way now
brakes are fantastic though
Offline sidecarphil
« Reply #9 on: 05 February 2009, 09:56 »
well i bought a MK3 VR6 ready for the conversion
the car looked like it had been run over by a herd of elephants  :grin:
but the engine ran and sounded good , so i thought yep i'll have it for 650 euros
the clutch was seized , and the brakes were siezed too
so off back to work with it on the trailer and all was removed carfully and lebeled every wire LOL
but i took the sump off for a look in and i was going to change the chain as i have seen a lot of problems with this when it is fitted to the car AND i saw lots of little pieces of metel in the strainer of the oil pump , :angry: :angry:
so i am going to rebuild it and add a ported and polished head , and a performance cam (any ideas ) ??
i also was going to use the interior loom modded for the MK2 dash and MK3 stalks BUT the interior loom has been cut about so mush for alarms , stereo , ECT that i decieded not too
i sourced a late dash loom , fuse box and elec window winders
i also bought a set of electric mrrors from a corrado , was going to use the dash but it was so cold i gave up taking it out  :embarassed:
but till the engine is re built i have repaired the engine bay wiring loom and am driving it as a 1.8 still  :cry: :cry:
