Author Topic: Rev counter signal/ audi gauge wiring  (Read 1338 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« on: 15 January 2009, 21:45 »
hi I need some info on how to get my mk2 clocks working with the mk3 coil. Which wire do I need to connect where to get this up and running?  :undecided:
Also ive got the audi pressure guages, There are 3 sensors on the oil housing. Which one of these controls the oil pressure. Also I need to know where the oil temperature sensor is.
Many thanks
Offline danny_p
Re: Rev counter signal/ audi gauge wiring
« Reply #2 on: 15 January 2009, 22:26 »
open up littel flap covering connections between the coil and ignition amp in the the mk3 coil and solder wire to to LT connection,  then ether click littel flap back up or seal with epoxy
all the VW's have gone bar 1.
« Reply #3 on: 16 January 2009, 17:54 »
cool think ive got that part. where does the other end go then?  :smiley:
« Reply #4 on: 19 January 2009, 15:12 »
fusebox faq ;)
« Reply #5 on: 23 January 2009, 20:40 »
had a go today at this. Lifted the flap up on the coil and soldiered the wire in place. (couldn't see LT connection so tried both). Wierd thing is the car wouldn't start with the wire attached??. Does the other end go to the tci which is F9?. Many thanks  :smiley:
« Reply #6 on: 24 January 2009, 15:31 »
all sortd now
