Author Topic: what Amp  (Read 5100 times)
Offline daniel-1986
what Amp
« on: 15 January 2009, 11:14 »
whats the best amp to run this sub
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_264367_langId_-1_categoryId_165748
its currently running off a Blaster 500w amp (250rms) but i think it will run better off a known amplifier
Offline troublestarter
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline jake
Re: what Amp
« Reply #2 on: 15 January 2009, 15:21 »
i had a JBL touring amp not too axpensive and did the job :smiley:
Offline Shady Pioneer
  • graphic designer.
Re: what Amp
« Reply #3 on: 15 January 2009, 18:23 »
I've got a 4 channel JBL GTO 1004e amp that's powering a sub and 2 components, holding up well with good sound and it's still alive after 7 months lol!
Offline Bootneck
Re: what Amp
« Reply #4 on: 15 January 2009, 18:42 »
To be honest it's a £20 sub,it's never gonna sound good. Why not Save and buy a Decent Sub and amp?
Good Advise is something men give when too old to set a bad example
Offline daniel-1986
Re: what Amp
« Reply #5 on: 15 January 2009, 23:07 »
with the sub i had in before i had to turn the gain down to stop it distorting where as with this i can turn it up without as much distortion
« Last Edit: 15 January 2009, 23:11 by daniel-1986 »
Offline sharki786
  • GOT BOOST??
Re: what Amp
« Reply #6 on: 22 January 2009, 22:15 »
hi,
id go for farenheit (power acoustic) or jbl or pioneer or even alpine. but make sure u get the correct amp 2 run it try this site, www.bassjunkies.com
they ok but if you av an audio shop local then go ther n they might be able 2do you a deal like a package. dont bother with power caps they stupid n for chavs (no offence to anyone on ere)  :wink: but ye id go for farenheit cz i got 2 12's in my car runnin 2000watts rms in total n that does sum serious damage & also depends on how you aim the subs if u want ur rear passangers with headaches then face it inwards if you dnt want you boot rattling then face it upwards n if you get rattling sounds then you need to sound deaden it.
 :grin:
shaf
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline LazyLunatic
  • MK3 20VT Project
Re: what Amp
« Reply #7 on: 27 January 2009, 20:35 »
sounds like a better idea tbh. your amp atm should be fine, as the sub wont perform much better with a different amp.
i suggest JL audio of you can afford it! or alpine type R if not. vibe blackair's are awesome too.
distortion is due to poor quality normally or a if the system has been poorly setup. or it could be because of mega vibration because of no sound proofing.
LL ;)
Offline AZIM
Re: what Amp
« Reply #8 on: 29 January 2009, 11:47 »
Theres plenty of good sub bargins in the classifieds
Just chose a good quality brand and you wont do any worse than youre original selection .
