Author Topic: reverse lights hmmmm why they not working???  (Read 5120 times)
Offline djianb
« on: 14 January 2009, 17:49 »
i had both reverse lights out so i bought two new bulbs from halfords took the covers off and fitted the new bulbs 1 didn't even have a bulb in lol neways i plugged the plugs back in and tested them but they don't work?? all the other lights work fine and couldn't see any wires missing to the main plug?? can anyone shed any light on this problem for me?
Offline Fatty B
Re: reverse lights hmmmm why they not working???
« Reply #1 on: 14 January 2009, 17:53 »
check the reverse light switch on the gearbox the wires break connecting to the switch. Also check the fuses
If your buying im selling!!!!!!!
Offline djianb
« Reply #2 on: 14 January 2009, 17:54 »
where are both of them on my mk 4 cause only just got the car
Offline Fatty B
« Reply #3 on: 14 January 2009, 18:07 »
reverse light switch is next to the starter motor on most 1.8 t some can be at the back of the gearbox nest to the diff on older cars. check the fuses in the fuse box on the right hand side of the dash when you open the door.
Offline richw911
« Reply #4 on: 14 January 2009, 20:07 »
mk4 maintenance + info section need friends  :wink:
Are you sure you have changed the right bulbs sounds like you have replaced the fog light bulbs? MK4 golf only has one fog light - and one bulb fitted.
If not look here:
http://www.golfgtiforum.co.uk/index.php?topic=87373.0
« Last Edit: 14 January 2009, 20:09 by richw911 »
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #5 on: 14 January 2009, 21:43 »
If not look here:
:D    :D
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline djianb
« Reply #6 on: 14 January 2009, 21:49 »
definatley changed the reverse light bulbs! i think lol?? which why is the reverse light?? there is 5 to choose from
Offline richw911
« Reply #7 on: 14 January 2009, 21:53 »
Its the bulbs at the bottom nearest the boot ( not the outside of the car) if that makes sense!  :grin:
« Reply #8 on: 14 January 2009, 21:55 »
Just line up the circuit board next to the lenses, & find the ones which the clear glass would cover!  :rolleyes:
Offline djianb
« Reply #9 on: 14 January 2009, 22:12 »
yeh definatley the reverse light cause just tested all the other one's? spose next thing is in the morning the fuse's??
