Author Topic: help please  (Read 2059 times)
Offline tdimike
help please
« on: 13 January 2009, 18:23 »
i have just changed my disks and pads on my tdi golf mk4 and when i start it up and press the brake STOP cums up on the dash i have conected the brake pad  sensor up any ideas thanks  :cry: :cry:
w0ffle
Re: help please
« Reply #1 on: 13 January 2009, 18:26 »
p
« Last Edit: 18 November 2024, 19:27 by w0ffle »
Offline tdimike
Re: help please
« Reply #2 on: 13 January 2009, 18:28 »
Offline Steve_PD
Re: help please
« Reply #3 on: 13 January 2009, 18:30 »
Did you top up the brake fluid  :undecided:
Offline tdimike
Re: help please
« Reply #4 on: 13 January 2009, 18:32 »
it looks full  :sad:
Offline GOLF_STU
  • THE_GIT
Re: help please
« Reply #5 on: 13 January 2009, 21:11 »
did the old pads have wire's? ps you have got the cap on havn't you?
V TEC KICKED IN Y'ALL!!!
Offline tdimike
Re: help please
« Reply #6 on: 14 January 2009, 07:08 »
yes the cap is back on and the new wire is on  :undecided:
Offline Rhyso
Re: help please
« Reply #7 on: 14 January 2009, 07:52 »
did you disconnect the battery before removing the brake sensor?
Offline oliver07
  • golf gti T 200BHP
Re: help please
« Reply #8 on: 14 January 2009, 08:50 »
just changed my rear calipers and this light came on when the fluid cap was of but went of when it was put back on try resetting it with vag com is there enough fluid in your bottle :grin:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: help please
« Reply #9 on: 14 January 2009, 14:01 »
That shouldn't make any difference - Besides, that would cause the brake pad warning light to illuminate, not the 'STOP' check brakes message to come on the display. ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
