Author Topic: 1.6 having 'issues'...  (Read 2377 times)
Offline Mk1Macca
Re: 1.6 having 'issues'...
« Reply #10 on: 20 January 2009, 10:54 »
thanks for the quick replies  :smiley:
The car was fairly recently serviced by VW, would they not have hooked it up and checked for faults, then cleared anything that was there?
The power terminal one seems confusing, so am choosing to ignore it... ahem...
would a dodgy temp sensor cause the revs to rise on their own, then stall the car out?
What about the Oxygen Sensor?
Offline ben1.8T
« Reply #11 on: 20 January 2009, 11:06 »
I would ring them then and see what they say. The oxygen sensor on my MG went and it ran fine didnt even know about it until it failed the MOT on emmissions.  :smiley:
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline Mk1Macca
« Reply #12 on: 20 January 2009, 11:14 »
It's whether it's affecting the current problem though....
Offline topher
  • Administrator
  • fully functioning
« Reply #13 on: 20 January 2009, 11:15 »
temp sender can cause those issues yeah
o2 sensor, well.. those things can have a mind of their own but i've never known a dodgy one cause problems like yours
Offline Mk1Macca
« Reply #14 on: 20 January 2009, 11:40 »
Brilliant. Temp sender it is.
Thanks for your help Topher :)
Anyone have a part number for it?
Offline topher
  • Administrator
  • fully functioning
« Reply #15 on: 20 January 2009, 11:53 »
haven't mate sorry, only got the GTI ones handy
pop into vw though they'll match it to your reg or vin number (it's worth lifting the bonnet to check they've given you the right one before you leave though, there are a few different ones that aren't interchangeable)
Offline richw911
« Reply #16 on: 20 January 2009, 18:59 »
00668 - Battery Power Voltage Supply Can sometimes be caused when you disconnect the battery   :wink:
Offline Mk1Macca
« Reply #17 on: 20 January 2009, 21:17 »
Bought / changed / codes cleared  :smiley:
took it for a test drive and didn't seem to have the problems of before and heated up much quicker. Going to drive it again tomorrow from the dead of cold to see if it's actually worked.
Thanks all so much for your help  :smiley:
