Author Topic: Whay does ARL engine mean???  (Read 10290 times)
Offline HandsyBoy
Re: Whay does ARL engine mean???
« Reply #10 on: 12 January 2009, 14:57 »
why on earth are they that expensive?  :shocked: :shocked: :shocked:
Life is racing, anything else is waiting...
http://www.camper-conversions.co.uk
Offline Rhyso
« Reply #11 on: 12 January 2009, 15:01 »
instead of the normal 225mm diameter our are the larger 240mm diameter - plus they have to cop with a lot of torque - as much as 50% more than the equivalent petrol engine
w0ffle
« Reply #12 on: 12 January 2009, 16:16 »
p
« Last Edit: 18 November 2024, 19:29 by w0ffle »
Offline Rhyso
« Reply #13 on: 12 January 2009, 16:23 »
Indeed, plus you will probably need a flywheel and the labour to have it fitted.
yeah i forgot to mention that price i quoted included a new flywheel, release bearing and the labour to ft it
w0ffle
« Reply #14 on: 12 January 2009, 16:41 »
p
Offline Steve_PD
« Reply #15 on: 12 January 2009, 18:17 »
Well thats just put me off..... How much are clutches fitted?
for our engines approx £900 - not cheap but worth every penny!
and the rest  :cry: £550 for a clutch - £250 flywheel (£450 if you go VW) - release bearing + fitting around £200+
worth it tho  :cool:
Offline Steve_PD
« Reply #16 on: 12 January 2009, 18:21 »
Also you'll want new brakes as the standard ones are poo
Offline Rhyso
« Reply #17 on: 12 January 2009, 19:17 »
Tut tut Rhyso,
You don't normally seem to cross the T's and dot the I's :P
well if people did a little research then they'd know the price i quoted wasn't just for the clutch.  But then people are lazy............
Offline HandsyBoy
« Reply #18 on: 13 January 2009, 08:41 »
Either way im not shelling out that much for a clutch if i can prevent it. No remap for me  :sad:
Offline Rhyso
« Reply #19 on: 13 January 2009, 08:45 »
Chicken  :tongue:
you only live once!! and your clutch will give up the ghost eventually  :laugh: :laugh:
