Author Topic: will 16v oil jets on a 8v engine?  (Read 2842 times)
Offline Gareth
« on: 11 January 2009, 22:24 »
hi,
i have seen that on the 16v enigne the have oil jets that spray up at the pistons and im thinking they would be a nice add on for my 8v :) but does any one know if they will fit? cheers
Offline danny_p
Re: will 16v oil jets on a 8v engine?
« Reply #1 on: 11 January 2009, 23:56 »
chould fit them but no need, but you'll also need the bigger oil pump
all the VW's have gone bar 1.
Offline Gareth
« Reply #2 on: 12 January 2009, 00:14 »
i am using a bigger febi oil pump :) i am taking my 1.8gti to 2.1gti   :laugh: i thought it would help oil get up to the pistons?
« Last Edit: 12 January 2009, 00:16 by Gareth »
Offline danny_p
« Reply #3 on: 12 January 2009, 00:55 »
the oil jets arn't about lubrication there about cooling.   pistons need F all oil problem with oil squirters is they can get to much oil and the scraper ring has troubel dealing with the excessive oil film on the bores, hence why some vw engine's got a reputation for useing oil
Offline paultownsend
« Reply #4 on: 12 January 2009, 11:26 »
just buy a 2.0 agg lump. any myths about them not revving are just untrue.
iv only a 268' newman and it pulls strong to 6.5k, but the torque drops off  around 5.5. il try find my rr plot.
i got my 2.0 for £80 delivered and it was perfect. around £150 all in with gasketts, fluids. cheaper than a rebuild.
what pistons you using for the 2.1?
Offline Gareth
« Reply #5 on: 12 January 2009, 20:09 »
ok cheers for the info guys! but its a little to late for me to buy a 2.0 now ive all ready started :P im using KS 83mm pistons and the 2.0 crank :D
« Reply #6 on: 14 January 2009, 01:00 »
that does sound a little fruity! :laugh:
Offline danny_p
« Reply #7 on: 14 January 2009, 01:35 »
1.9 D is the cranck for 2.1      95.5mm stroke  with 83mm bore
Offline Gareth
« Reply #8 on: 14 January 2009, 14:07 »
 :shocked: so i could grab the 2.0 liter crank out of a 1.9 mk2 diesel is that what you mean? i was going to buy a 2.0 crank that was going to cost me quite a bit :( cheers
Offline danny_p
« Reply #9 on: 14 January 2009, 15:35 »
i can supply you with 2.0  cranckshaft :)  and 144mm or 159mm rods
don't have any spare 95.5mm crancks, they come from aaz motors but they have habbit of eating keyway out so quite valuable
