Author Topic: clutch problem?  (Read 1470 times)
Offline GemGTI
  • Gemma
clutch problem?
« on: 11 January 2009, 21:17 »
Hello guys,
something weird happened to my clutch the other day. I went to get in the car and the clutch was wedged right to the floor! I find it hard to believe that I wouldn't notice this when getting out of the car after driving it as you always feel it springing back up into place when you take your foot off. I had to pull it back into position before I could drive it. Is there any chance it could have done this by itself over night? Could it be something to do with the cold weather? Could it have frozen? It seems to have been fine since, although I do sometimes struggle to get it into 1st gear.
Any suggestions would be helpful.
Thanks,
Gem
2002 Golf 1.8T GTI
Offline Rhyso
Re: clutch problem?
« Reply #1 on: 11 January 2009, 21:19 »
get the master cylinder and slave cylinder checked out - you could be loosing pressure  :undecided:
Offline GemGTI
  • Gemma
Re: clutch problem?
« Reply #2 on: 11 January 2009, 21:32 »
what does that mean? (sorry - a bit clueless!)
Offline Rhyso
Re: clutch problem?
« Reply #3 on: 11 January 2009, 21:40 »
you have a master cylinder for the brake and clutch system - the seals inside can fail leading to loss of pressure
the slave cylinder sits on top of the gearbox and can experience the same problem
is your brake pedal ok?? or is it just the clutch pedal you've had a problem with?
« Last Edit: 11 January 2009, 21:44 by Rhyso »
Offline GemGTI
  • Gemma
Re: clutch problem?
« Reply #4 on: 11 January 2009, 21:49 »
Brake pedal seems fine
Offline jake
Re: clutch problem?
« Reply #5 on: 11 January 2009, 22:08 »
ive had the same problem before, i was sat at the traffic lights and then i couldnt get my gear into first. I thoght o dear gear box nakered.
So i called out the AA but while waiting i noticed that clutch pedal was a not fully retracted, so i put my foot under it and it sprang back
So everything was ok, never done it since, i wouldnt worry unless its doing it alot or often. Sometimes like all things, things dont work
properly. might be a one off like me :smiley:
Offline ben1.8T
Re: clutch problem?
« Reply #6 on: 12 January 2009, 08:44 »
Mine done this I had the slave cylinder replaced is fine now.  :smiley:
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
