Golf mk1
mk1 cabrio owners
Topic: mk1 cabrio owners (Read 3951 times)
Dinky
Guest
mk1 cabrio owners
17 June 2004, 22:20 »
Wots ur revs read wen in third-goin up to 30mph into fourth? how ur engine sound?Think my cabrio is playin up?!
Just wanna check,thanx
Dinky
gibby
Forum addict
Champions of Europe,ooh ,just the five times then!
Re:mk1 cabrio owners
18 June 2004, 13:57 »
Hi Dinky, I dunno what the revs are without looking but if I remember I'll have a look on my drive home tonight, but there's not any untoward engine noise though that's for sure.
......now officially dubless.
Dinky
Guest
18 June 2004, 17:49 »
Thanx Gibby!
Aye the engine is sounderin louder than normal wen i think the cars not pullin like!Gonna hav a look at her tmw-if weather is gud!
Thanx again Gibby!
Dinky
Last Edit: 18 June 2004, 17:50 by Dinky
gibby
Forum addict
21 June 2004, 12:32 »
No worries Dinky. I did remember to have a look at the revs too on the way home on Friday, I reckon, when driving steady and changing from 3rd to 4th I only hit about 1400 rpms, hope this helps.
Dinky
Guest
21 June 2004, 18:31 »
Yeah thanx Gibby-just confirms that i do hav a problem!
Mines goin way upto 3000 practically!
One last thin hun,wots urs idle at?
Mines @750 but was thinkin of takin it up to 1000?
Cheers!
Dinky
Last Edit: 21 June 2004, 18:59 by Dinky
eyeletboy
Here all the time
22 June 2004, 00:13 »
mine was on 750 rpm.seemed to be wandering a bit so i took it up to 900 rpm and it's fine now
danhock
Reply #6 on:
22 June 2004, 08:47 »
mines idling at about 600rpm and sounds rough...
I would adjust it by my idling adjust screw is broke.. :'(
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
AdamB
The Perfect Storm
Reply #7 on:
22 June 2004, 10:28 »
Mine is idling at an indicated 1200 rpm on the rev counter, but I will check it with the MFA later, however the idle screw is wound right down and it would appear that I cant reduce it any more. I think it is idling high then.
I don't own this anymore - I just can't be arsed to change the picture
richandhazel
Global Moderator
Forum addict
Reply #8 on:
22 June 2004, 11:07 »
If you're idle screw is all the way in and you're still getting a high idle then unmetered air is being drawn..........in other words, you have a vacuum leak.
Last Edit: 22 June 2004, 11:08 by richandhazel
gibby
Forum addict
Reply #9 on:
22 June 2004, 13:04 »
Quote from: Dinky on 21 June 2004, 18:31
Cheers!
Dinky
Dinky, mine is spot on 1000 rpms when it's warmed up and it doesn't budge at all, it's spot on. I'm just showing off now
Golf mk1
mk1 cabrio owners
