Author Topic: Brake lights fuse keeps on blowing??  (Read 2737 times)
Offline MK4_20VT
« on: 17 June 2004, 08:52 »
My 10amp fuse on my brake lights has started to blow everyday for sum reason.  ???
Also I can see my brake lights working when I have NO key in the ignition, iv never noticed this before, is this normal on the first ever MK2's?????
Any advice for things to check
Offline J a m e s
Re:Brake lights fuse keeps on blowing??
« Reply #1 on: 17 June 2004, 09:37 »
check the earths in the rear of the car, coming of the lights?
Offline JMallows
« Reply #2 on: 17 June 2004, 14:25 »
The brake lights do work with the ignition off. ~Take off the bulb holder in the back and check all hte connections, then check on the bulb connection itself, could be shorting cos of a funny bulb, or a funny holder. Obviously do both sides! Then follow the wire through to find out where the earth is located (left hand side behind the panel) Check they all attched to it properly etc... If you have a high mount, or any modifications check this too.
If this fails, check the operation of the switch located behind the pedal. Could be broken and when you break, it shorts? Could also be the fuse box itself... Finally check the potential across the terminals while someone applies the brakes, and the current.
A clever person solves a problem. A wise person avoids it.
Offline MK4_20VT
« Reply #3 on: 18 June 2004, 08:47 »
I found a DIY cable from the old fuel cut off switch, were the previous owner had attached 1 of the leads to the brake switch for some reason?
Iv disconnected it & it seems to have stopped blowing fuses & EVEN better the MPG reading on the MFA is working now  ;D
vwsystems
« Reply #4 on: 22 June 2004, 23:52 »
the fuses only blow if more than 10amp gets pumped down the wires.......... or theres a short circuit!
or the bulbs are pulling more than 10amp..........
sometimes people put a 10amp in place of a 15amp.....
it lasts a while and burns out slowly!
looked in the book the brake lights are 10amp.....so your ok.....
Offline MK4_20VT
« Reply #5 on: 23 June 2004, 06:31 »
I checked my manual to see what fuse should be there & it is meant to be a 10amp, but on post 88-89 models i'm sure the fuse is a 30amp.  It must have more stuff attached to the later models  ???
Thanx for you replys  ;D
