Author Topic: Correct Torque Settings for Mk5 GTI  (Read 1902 times)
Offline illyun
« on: 04 January 2009, 14:00 »
Anyone know the correct wheel hub torque settings for the Pescaras on the Mk5 Edition 30?
Mk1 GTI Campaign, Mk5 GTI Edition 30, Mk6 GTI (Coming Soon...)
Offline dan_apps
  • too low for british roads!
Re: Correct Torque Settings for Mk5 GTI
« Reply #1 on: 04 January 2009, 14:10 »
not a clue fraid, but its in the manual as i checked when i did my monzas last.  :smiley:
Offline illyun
« Reply #2 on: 04 January 2009, 14:57 »
Brilliant.  I thought it might be, but I was too lazy to dig it out and check  :grin: :grin: :grin: :grin:
Offline Dogbucket
  • Golf R32 / TVR Chimaera 450
« Reply #3 on: 04 January 2009, 15:46 »
I normally do 120nm, which I got from a VW workshop manual at some point.
Offline Hurdy
« Reply #4 on: 04 January 2009, 17:33 »
Yep, 120nm :cool:
Seat Leon Cupra Black 290 DSG
Offline Pando
« Reply #5 on: 05 January 2009, 09:49 »
I used to do 118 lb ft on my beemer
Offline Steve Baker
« Reply #6 on: 05 January 2009, 10:51 »
120NM
or 90LbFt
Offline illyun
« Reply #7 on: 05 January 2009, 13:06 »
Thanks guys.  Tried to jack the car last night in the snow and while I found the rear jacking point, I couldn't find the front ones - I thought I did but then heard a crack when trying to jack it up and decided not to proceed any further  :shocked:  A bit of the plastic cracked underneath  :sick:.
Offline Rollini
« Reply #8 on: 05 January 2009, 16:09 »
isn't there little triangles on the underneath of the side skirt to indicate where to jack it up? or are you not jacking it up for the side?
Offline illyun
« Reply #9 on: 05 January 2009, 16:43 »
No, not for the GTI.  There are small semi-circle cuts along the rail underneath - behind the trim.  I found the rear one easy enough, but the fronts were not so east to identify.  Had the wheels put back on by a garage today and looked where they lifted the front of the car but it seemed to be the same as where I did it from?!  :rolleyes:
