Author Topic: Rear axle  (Read 850 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Rear axle
« on: 03 January 2009, 18:43 »
hi another quickie. Ive gone wide track on the front with the toledo sub-frame setup. Will I need to swap the rear axle over to achieve wide track on the back, Ive read somewhere about spacers?. Secondly I am thinking of doing the bushes, I hear the poly ones are easiest to do but are not as good as vw ones. suggestions appreciated. cheers   :smiley:
Offline richard s
Re: Rear axle
« Reply #1 on: 03 January 2009, 19:26 »
ive seen some spacers that bolt behind the stub axle but cant remember wether i saw them on here or not
Offline Diamond Hell
  • Opinions я Us
Re: Rear axle
« Reply #2 on: 03 January 2009, 19:32 »
Just fit the Toledo rear beam, with new VAG bushes and see how you find it.
The firmer polybushes are supposed to make the rear end snappy, but that's probably a comment from people used to sloppy old bushes and lacking car control.
Re: Rear axle
« Reply #3 on: 03 January 2009, 21:30 »
N1 rear toledo axle it is then i here the vag bushes are rather awkward to fit where as the poly ones are easier
Offline DOA
Re: Rear axle
« Reply #4 on: 03 January 2009, 22:41 »
Id second that, should mean less geometry change but whos to argue with rumour lol.
Re: Rear axle
« Reply #5 on: 04 January 2009, 09:49 »
you might want to measure the beam from axle plate to axle plate before you swap it, some of the widetrack car rear beams arn't actually any wider than the normal ones.
