Author Topic: a few abf questions  (Read 5697 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
a few abf questions
« on: 31 December 2008, 09:27 »
If the 4 branch doesn't work can I use the ABF down pipe or do I need a 16v one
Also can anyone help me locate where this wire goes, its from connection bock f
Thank alot
Re: a few abf questions
« Reply #1 on: 31 December 2008, 09:41 »
The MK3 manifold n downpipe will fit, you'll just need to find a way to bridge the gap between the flange on the downpipe and your front silencer.  A MK3 cat bypass pipe would probably be a good start, but I dont know what bore the MK3 pipe will end at?
As for that wire is it green/red, and I asssume thats from the ABF engine loom right?
« Reply #2 on: 31 December 2008, 09:47 »
Yes mate it is the ABF loom. I threaded it all through the bulkhead and a came out of the connector. Havn't a clue where it goes now :cry:. Few other wires too i'm unsure about, ill tackle that when i get there. Also do you know if the cross member of the toledo will fit the golf as the rad mount will obviously be spot on.  :smiley:
« Reply #3 on: 31 December 2008, 09:52 »
what year toledo, and do you mean both halves of the subby or just the rad support bit?
edit: I've just checked, for all years of toledo fitted with an ABF the radiator support half is the same as a MK2 one, the only difference is the engine support half allows you to use the MK3 style ABF front engine mount :)
« Last Edit: 31 December 2008, 10:08 by rubjonny »
« Reply #4 on: 31 December 2008, 09:55 »
the donor car wasnt an automatic was it?
« Reply #5 on: 31 December 2008, 10:04 »
ok I'm 70% sure it goes to F/9, which is for the rev counter feed.  Can you check G1/12 on the ABF loom to see if there is a red/black wire there?
« Reply #6 on: 31 December 2008, 10:05 »
no not an auto, 1995. Yes just the rad support. I did notice the engine mounting is slightly different. could this be used too??
« Reply #7 on: 31 December 2008, 10:09 »
I've just checked, for all years of Toledo fitted with an ABF the radiator support half is the same as a MK2 one, the difference is the engine support half allows you to use the MK3 style ABF front engine mount :)
« Reply #8 on: 31 December 2008, 10:14 »
ok can't see red/black wire in g1?. Theres one in f
« Reply #9 on: 31 December 2008, 10:19 »
I wonder whether the front engine mounts make the engines sit higher or lower? might help with the 4 branch maybe.
